I have 2 15in t1s in a small ported box (prob like half the size it should be) with a planet audio amp 2400rms in a ext f150
amp- http://www.planetaudiousa.com/main/591
My problem is deciding what ohm to go with wiring em up. I had them on 2ohm for awhile and they sounded decent. I just recently rewired them to 1ohm and they sound like shit... i mested with my amp settings and still no good. They just dont seem to be as loud... which i dont understand cuz there at 1 ohm. They are the dual voice coils but with these new version subs it only has one terminal. and the switch to change it from 2ohm or 8ohm.
I was figuring it sounded bad because my box is to small or not enough air space for 1ohm. Would 8ohm sound better then 2?
I don't know how you were wired to 2 ohm, then re-wired it to 1 ohm... Not exactly possible.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
You can't go from 2 ohm to 1 ohm with your wiring and coil configuration.
Either you have d2's wired to 2 ohm or .5 ohm or you have d4's wired to 4 ohm or 1 ohm.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Since the power series have the switchable ohm plug in i have either 2ohm or 8ohm. The guys that wired it just had the positives and negatives of each sub wired straight to my amp. So 4 wires all together coming out of my box.
Then for the 1ohm he put the positive and negative from 1 sub to the other sub and the positive and negative of the final sub to the amp
So much fail!
You're cool.
Thanks i appreciate it... just trying to figure this out i dont really know that much
I've never messed with subs that have the switches like that, so maybe somebody else could help point that out for you.
But what I would do is keep the 2 ohm switch. And wire the subs just like this for a 2 ohm load.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
So much fail!
You're cool.
You noticed that too? Thank you for pointing it out and boosting my self esteem. :popcorn:
*Rebuid in progress*
Actually, it was me calling you a douche. But take it as you will.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
