2 Fi Bl 10's box design. *Think i finally got 'er right!*
TylerParrish
I was thinking more along the lines of this:
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
i can see a few reasons why not to go with that idea. even with bracing in there, it's way too big and it would still be tuned higher than 34 Hz
Got that all wrong lol, here what it meant to be:
If you are willing to shrink down the baffle and have a partially external port then something like this. Sure you can't shrink it down more?
In any case look into engaging the subsonic filter and set it very near the tuning frequency.
Still think the 12s version I posted would do better but all comes down to what you are wanting of course.
We still talking about a pair of tens?
yes, I'm tryin to get it don to 3 cubes with a 6 inch aero but i just cant, wanna take a try at it?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
port to the side. you have more width that way.
I know, but i was gonna seal it off......, that's the only reason i keep porting to the front
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
well you certainly don't need 50 square inches of port. around 30 square inches should be plenty. Just shrink the depth and width till you get the right volume.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
last box design had like 29 sq in of port, but it's still 3.5 after all displacements. Maybe I just can't have an aero port in this application
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Porting forward with an aero doesn't work very often in trunks.
If you just need a couple extra inches, you can try a pair of 4" ports, rather than a single 6"
otherwise if you have to go slot, here's some rough numbers for you.
box dims.
12.5 high, 30 wide, 21 deep.
1 extra baffle
port dims.
11 high, 3 wide, 26 long
that's 33 sq inches of port
net volume is ~2.4, so 1.2 per sub
tuning @ 33hz
If you really wanna do an aero though, consider porting to the side. seen plenty of setups like this, and they usually do pretty well.
More box builds
  • Who's Online   0 Members, 0 Anonymous, 2479 Guests (See full list)
