ReeseChamp Posted September 6, 2012 Report Posted September 6, 2012 this is the subwoofer im getting, it says dual 4-ohm and the pictures show 1 and 4 ohm jacks, does that mean the 1 is actually 2 and the 4 is actually an 8? http://www.amazon.co...r/dp/B004UFHY8C if it is then will this amp provide enough power for the sub to get the most power? http://www.vminnovat...-Amplifier.html do you look for amps based on RMS or peak power? the one i linked matches the rms power at 2 ohms and says its max power is also 2000w so it sounds perfect but im not sure if im missing something on a side note: what ported enclosure dimensions would be good for the sub? Cutout Diameter: 13-7/8 inches Mounting Depth: 8-3/8 inches Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS
ToNasty Posted September 7, 2012 Report Posted September 7, 2012 Alwayd rms power. Also look at the ohms of the amp ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ReeseChamp Posted September 7, 2012 Author Report Posted September 7, 2012 Alwayd rms power. Also look at the ohms of the amp the amp does 1000w at 2 ohm, 500w at 4 ohm, 2000w at 1 ohm it says Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS
Skullz Posted September 7, 2012 Report Posted September 7, 2012 The sub is a D4 and you can only wire it to either 2 ohms or 8 ohms and you will need an amp capable @2 ohms for that sub. If you can afford this amp it would be a far better option than the one you listed as this one is capable of 1k @2 ohms which your looking for and the quality of the build will far exceed the crunch's. http://www.ebay.com/itm/Alpine-MRP-m-1000-/320977791202?pt=Car_Amplifiers&hash=item4abbc468e2 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ReeseChamp Posted September 7, 2012 Author Report Posted September 7, 2012 The sub is a D4 and you can only wire it to either 2 ohms or 8 ohms and you will need an amp capable @2 ohms for that sub. If you can afford this amp it would be a far better option than the one you listed as this one is capable of 1k @2 ohms which your looking for and the quality of the build will far exceed the crunch's. http://www.ebay.com/...=item4abbc468e2 the amp i have listed has the same power i see, how do you see the quality difference of it? Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS
ToNasty Posted September 7, 2012 Report Posted September 7, 2012 Cause crunch may have that power but not constantly. The alpine will ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Skullz Posted September 7, 2012 Report Posted September 7, 2012 The crunch has half the power of the alpine and the quality is better than the crunch. Here are the specs on the crunch, the power output @2 ohms is 500w rms. Power One Series Monoblock Class A/B Car Amplifier RMS Power Rating:4 ohms: 250 watts x 1 chan. 2 ohms: 500 watts x 1 chan. 1 ohm: 1000 watts x 1 chan. [*]MAX Power Rating: 4 ohms: 500 watts x 1 chan. 2 ohms: 1000 watts x 1 chan. 1 ohm: 2000 watts x 1 chan. [*]SEPP Class A/B analog amplifier [*]Pulse Width Modulated MOSFET power supply [*]Wired remote bass level control included [*]LED power (green) and protect (red) indicators [*]Variable Bass Boost (0 to +12 dB bass boost at 50 Hz) [*]Slow un-mute soft start turn-on [*]Mono channel operation [*]Preamp RCA outputs to daisy chain multiple amps [*]3-Way System Protection circuitry (thermal, overload, and speaker short protection) [*]Dual speaker terminals simplify the hookup of multiple speakers [*]Heavy duty aluminum alloy heatsink for extreme heat dissipation [*]Silver-plated RCA level inputs [*]Silver-plated screw terminals [*]Input sensitivity: Level: 200mV-6V[*]Variable low-pass filter (40-150 Hz, 12 dB/octave) [*]Subsonic filter (15-55 Hz) [*]Damping factor: >200 [*]Frequency response: 10-300 Hz [*]Dimensions: 17-15/16"L x 9-1/8"W x 2-1/16"H [*]4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier. [*]Authorized Internet Dealer [*]1-year Manufacturer's warranty Product History: 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ToNasty Posted September 7, 2012 Report Posted September 7, 2012 I have that exact same alpine 1000 on my level 4. Its awesome ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ReeseChamp Posted September 7, 2012 Author Report Posted September 7, 2012 The crunch has half the power of the alpine and the quality is better than the crunch. Here are the specs on the crunch, the power output @2 ohms is 500w rms. Power One Series Monoblock Class A/B Car Amplifier RMS Power Rating:4 ohms: 250 watts x 1 chan. 2 ohms: 500 watts x 1 chan. 1 ohm: 1000 watts x 1 chan. [*]MAX Power Rating: 4 ohms: 500 watts x 1 chan. 2 ohms: 1000 watts x 1 chan. 1 ohm: 2000 watts x 1 chan. [*]SEPP Class A/B analog amplifier [*]Pulse Width Modulated MOSFET power supply [*]Wired remote bass level control included [*]LED power (green) and protect (red) indicators [*]Variable Bass Boost (0 to +12 dB bass boost at 50 Hz) [*]Slow un-mute soft start turn-on [*]Mono channel operation [*]Preamp RCA outputs to daisy chain multiple amps [*]3-Way System Protection circuitry (thermal, overload, and speaker short protection) [*]Dual speaker terminals simplify the hookup of multiple speakers [*]Heavy duty aluminum alloy heatsink for extreme heat dissipation [*]Silver-plated RCA level inputs [*]Silver-plated screw terminals [*]Input sensitivity: Level: 200mV-6V[*]Variable low-pass filter (40-150 Hz, 12 dB/octave) [*]Subsonic filter (15-55 Hz) [*]Damping factor: >200 [*]Frequency response: 10-300 Hz [*]Dimensions: 17-15/16"L x 9-1/8"W x 2-1/16"H [*]4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier. [*]Authorized Internet Dealer [*]1-year Manufacturer's warranty Product History: ohhh good catch ill look into the alpine, its double the power for less than double the price so i would think its worth it Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS
ToNasty Posted September 7, 2012 Report Posted September 7, 2012 You get what you pay for. Dont buy stuff cause it cheap ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
