So i recently picked up an encore e4 security system and have it mostly figured out except for one thing.
I am putting it in an 07 corolla.
Here is the 12 volt's wiring diagram:
12volts
white (25A), black (15A)
ignition harness
Starter red + ignition harness
Second Starter N/A
Ignition black/white + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Keysense blue/black - ignition harness
Power Lock green - driver kick, 10 pin plug
Power Unlock blue/yellow (double pulse) - driver kick, 10 pin plug
Lock Motor blue 5wi driver kick, blue 12 pin plug
Unlock Motor red 5wi driver kick, blue 12 pin plug
Parking Lights+ green + driver kick, harness to rear
Parking Lights- green/white - headlight switch
Hazards yellow/black - flasher relay left of fuse box
Turn Signal(L) green/black + flasher relay left of fuse box
Turn Signal® green/yellow + flasher relay left of fuse box
Reverse Light red/black + front of fuse box, 10 pin plug
Door Trigger red - front of fuse box, 10 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin red/white - light in trunk
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black ac ECM, far right plug, pin 5
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake red/black - parking brake switch
Horn Trigger green/yellow - horn switch
The problem is the power lock and unlock functions.
The alarm can be programmed to work with both cars that have positive lock, and negative lock functions.
But in the diagram it says:
Negitive for power lock
negitive for power unlock (double pulse)
So how do I go about this?
Thanks in advance!
wire the blue and green wires from the alarm to the Power Lock green - driver kick, 10 pin plug
