ChevyBoy95 Posted September 10, 2012 Report Posted September 10, 2012 in my brothers truck, him not being the audio junkie, has an issue, and im not 100% on what it is either. When his bass amp turns on it plays music for about 5-10 seconds then a progressively louder static/thumping happens and wont stop till the truck is turned off. We have switched the H/U with no change in the issue. Any leads to what it could be? the amp? and no i havent had the time to switch the amp out and try another. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
aerickson Posted September 10, 2012 Report Posted September 10, 2012 Could it be the rca? Or maybe a bad ground.
ChevyBoy95 Posted September 10, 2012 Author Report Posted September 10, 2012 a bad ground wouldnt let the music play perfectly for the first 5-10s then mess up(or at least i wouldnt think). and no other speakers do it(the others are on HU power) Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
DubNDodge Posted September 10, 2012 Report Posted September 10, 2012 Sounds like enigne/alternator noise, especially since it stops when the truck is turned off. It can be fixed with a better ground I believe. I am not exactly sure though. (not a pro) '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
ChevyBoy95 Posted September 10, 2012 Author Report Posted September 10, 2012 well it sounds almost like a double bass pedal with no rhythm and static mixed with it, but the static is not as loud Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
