How to wire multiple batteries?
As the title says....how do you wire say a battery up front and 2 batteries in the back? Also, do i need a fuse for both the back batteries as well as for the one up front? Any other useful info for wiring multiple batteries is also appreciated
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Not sure about the way to wire, I've heard parallel wiring is only suggested if you have an aftermarket Alt, because it's too much strain on stock alts. But I would definitely fuse between the batts.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
so how would i wire it up without being in parallel? Since i do have a stock alt for now? just run the power and ground to the frame? Seems like it would be more effiecient in parallel....
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Don't wire it any other way other than parallel or your next thread will be on how to stop car fires faster.
raptorman your going to have a lot of noobs mad at you if you keep tellin people that...
why is that? oh shit, conflicting replies, time to get some info backin people's info.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Connect all the positives to positives and negatives to negative, parallel. If you don't want to do a negative run from front to back do the big 3 up front and make sure you find a good spot to ground in the back. You need to put a fuse within 18" of of the batteries in the front and the back.
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
Just run parallel, + to +, - to -.
For the fusing, the safest way is to put a fuse between each battery. Me personally, I would only fuse the long run of the front to rear, then keep the rear 2 batteries non-fused.
Well, only other way to wire them is series. Which would be + to -, - to +. Do we really need to go over why not to do that?
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
If you wire in series you'll be running 24v or higher depending on how many batteries were talking about
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
series will double the voltage..doubling voltage = oh shit! wtf!....Wire them in parallel, search the other threads asking this question and you will find your answer much easier with much more input
I'm doing a run of + and - from the front, no need to ground in the back. And if i put 2 batts in the back, should I have a fuse before the first one and inbetween then 1st and 2nd one, or just 1 right before the 1st one?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 1234 Guests (See full list)
