lextruck Posted September 14, 2012 Report Posted September 14, 2012 Im wondering how many batteries a 300 amp alt can keep charged in a daily driver and how many watts I can run off them. Either XS power or Batcap batteries not sure yet.
HunterJohnson Posted September 14, 2012 Report Posted September 14, 2012 couldnt it charge as many as you have? Like 10 group 3100 batteries? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
HunterJohnson Posted September 14, 2012 Report Posted September 14, 2012 You would be running off mostly battery power if you had 15000 watts, but then when you stop playing your system your alt will charge the batteries back up? Just guessing Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
CleanSierra Posted September 14, 2012 Report Posted September 14, 2012 The amperage draw is more what you need to know to have that question answered, not wattage. Amperage needs come from what wattage your amps are needing at a particular efficiency, at a particular voltage. So you need to know what kind of pull the amps are gonna want before you can figure out which amps to get. A battery bank and HO can only replenish what is being demanded. Im not the one you want to try to troll. Just a fyi for you.
ChevyBoy95 Posted September 14, 2012 Report Posted September 14, 2012 essentially as many as you want, but what your amplifiers amp draw will be a determining factor on the decision of what to do with an electrical system. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
lextruck Posted September 14, 2012 Author Report Posted September 14, 2012 I want to run 2 rf 2500.1s and a 4 channel. Just don't wanna give up my AC for a second alt if possible. So was checking possibilities of one alt and several batteries instead.
