ItsMoldyYo Posted September 19, 2012 Report Posted September 19, 2012 I have a hifonics bxi1610d amplifier... heres what i need to know.... Its 1600 x 1 @ 1 ohm, it has two speaker wire terminals.... so to get the amp to see 1 ohm with two subs running from it what ohm subs do i need??? If that makes sense to anyone..... I was told 2 dual 4 ohm would make the amp see 1 ohm, wire the subs for 2 ohms and hook them up to the 2 terminals..... This person said that the 2 terminal run into one inside the amp.... Anybody know?
n8ball2013 Posted September 19, 2012 Report Posted September 19, 2012 you need dual 1s or dual 4s. and yes the terminals are all one inside the amp. they just put two on the outside for wiring ease. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ItsMoldyYo Posted September 19, 2012 Author Report Posted September 19, 2012 wiring dual 4 ohms to 2 and hook em up then nate, that will split the 1600 to 800 right?
206xtreme Posted September 19, 2012 Report Posted September 19, 2012 It's a bit more compicated! But yes, consider it as each of your subs gets 800W. In fact each of your subs take the same voltage because of parallel wiring and what is split is the output amperage. When we say that parallel connected speakers get the same power means that they get the same power vectorial and not cumulative. So if we have 200 watts in this particular impendance, then each speaker A B or C gets 200watt (and not each ONE gets 200watts, 200+200+200=600watt). Can't be so specific on what I mean cause of the difference in language. It's too difficult to find out what is the exact power each speaker gets and requires high level math etc... If you get dual4 subs, wire them parallel each and parallel together. So you get the 1st sub, wire the positives together, wire the negatives together. You do the same with your other one. Your multimeter must read 2ohms per sub. Then you wire the one positive of the 1st to the 2nd sub and do the same with the negatives. After you wire them to the amplifier (positive to positive and negative to negative). 2007 Peugeot 206 1400cc 75hpHead Unit: Pioneer DEH 80PRSSpeakers+Tweeters Amplifier: 2 x Hifonics Colossus Generation X3Bass Amplifiers: 2 x Taramps HD8000 (quadraple copper terminals by Toolmaker Metalworkz)Tweeters: 6 x Digital Designs VO-B2 + 4 x Beyma CP21/fMidrange Speakers: 20 x 8" Beyma 8M100 NdSubwoofers: 2 x Digital Designs 9918 walledAlternators: Mechman 320A universal + Bosch 260ARCA: Dragster OFC twisted triple shieldedWires: 0gauge big3 upgrade with SP audio, Currents with SP audio, Grounds with Rockford FosgateBatteries: 980AH of power with copper rails.Alarm: Python 5303P So far 161.4 dB with a Cadence 9kW @ Salamina 2014.
severancej Posted September 19, 2012 Report Posted September 19, 2012 Wow thanks man nice explanation 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
