do i need a battery or not
adding a battery will help, but it likely wont solve the voltage drop problem.
that gets fixed with a new alternator.
I Def ain't finding what I'm looking for everything is tuned calibrated wired right apparently my batt can't keep up completely with my set up so like I stated what is a good battery to add to my set up for the trunk what would keep my amps happy and not dipping below 12.6 is a xs 925 sufficient enough do I need a bigger batt than that maybe smaller ?
If you are dropping voltage like that while cruising a battery is just a band-aid. You need a bigger alt.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
to kranny i already got one under the hood you saying its good to get another one to add in the back? what you think about the kintetic 1800?
so any suggestions as to what battery i should add in my trunk to keep my volts in a good zone
  • Who's Online   0 Members, 0 Anonymous, 1589 Guests (See full list)
