fosgatefan821 Posted September 22, 2012 Report Posted September 22, 2012 Every time i turn radio on / off i get a popping noise. is there a relay or a different way to stop the popping noise?? maybe something like this item PAC TR-4 Remote Turn On Module. I will be replacing head unit in few weeks so I will have dash ripped apart to install what I need to elimnate that noise.. 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery
LoudPursuit Posted September 22, 2012 Report Posted September 22, 2012 Do you have an amplifier hooked up? If so check the RCA's and the ground. Also there are many topics on here about the same topic so try the search bar on the top. Headunit: Pioneer avh-1400dvd Subs: DC Audio lvl 4 18 with carbon fibre dustcaps Sub amp: Rockford T2500-1bdcp Mids & Highs: RF Prime 5.25's + Focal Polyglass 6.5s Highs Amp: RF T600-4 Batts: XS Power D975, XS Power D925 Alt: Mechman 270a Wires: Shok Industries 1/0, RF RCA's and Shok 12/8 gauge speaker wires Deadening: Second Skin TEAM DC TEAM SHOK
fosgatefan821 Posted September 22, 2012 Author Report Posted September 22, 2012 Yea I have the amps in my sig.. They did the same thing in my old car so I'm guessing its the RF amps ..I've had multiple head units on these amps over the yrs and same issue.. I just can't rememebr if i ever put a relay or anything to stop the popping issue . 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery
fosgatefan821 Posted September 22, 2012 Author Report Posted September 22, 2012 any other ideas? 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery
WastedTalent Posted September 22, 2012 Report Posted September 22, 2012 No idea man. Never heard of it before and I run RF amps. T1500-1bdcp and somethin else that I forget at the moment. Never truly heard of anyone having a popping noise. Sheena = pedobear
lifted_silverado Posted September 22, 2012 Report Posted September 22, 2012 If youre running mulitple amps its probably you remote turn on wire. You need a switch or relay in between to keep from drawing so hard all at one time Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins
fosgatefan821 Posted September 22, 2012 Author Report Posted September 22, 2012 yes i amp running 3 amps. i figured it is the remote . I was thinking a relay will stop the issue. just wanted to make sure if PAC or another company may have something made for it. 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery
