Do i need to upgrade anything???
I have a 2003 Pontiac Sunfire and I am putting in two RE Audio SE-X 15's with a Hifonics HFI 1500 watt amp ill be running the subs at 1 ohm... Questions are what gauge wire should i do for my amp, will i have to upgrade my battery or alternator the alternator is 105 amp and a stock battery, and lastly what gauge wire should i do for the Big 3.
Yes you need to. 0 gauge wherever you can. Upgrade your battery for sure, possibly 2. 1500 RMS amp? Might not need an alt... depends on if you play full tilt long. If you do/want to, then yes. But if no and you keep it down, then should be fine. If lights start dimmin or voltage drops, then yes. But upgrade those batts and I don't think you'd necessarily NEED an alt. Would be beneficial without a doubt.
Sheena = pedobear
Big as you can get. I know that helps none but typically, people get the same size battery as they have already for under the hood, since most don't wanna do a custom battery tray or can't cause of room. Then the other one, they usually go with the biggest they can afford or get.
Sheena = pedobear
Big 3 1/0
Kineitk or xs power in the back
Maybe a front battery
That amp doesn't put out rated man
That sounds so much cheaper haha :)
The hifi will do like 1k.
You can get away with just big 3 in 0/1 with stock battery. If you want overkill or are beefing up, add/upgrade a battery/alternator.
Unless you plan on upgrading in the future, 4 gauge power/ground should handle the amperage from that hifonics quite easily.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
You don't need 2 batteries for 1k-1.5k. Do big 3 and runs to the back in 1/0 and you should be fine. If not, an upgraded front battery should be fine.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • Who's Online   0 Members, 0 Anonymous, 814 Guests (See full list)
