Please help me with my wiring
I already have a + and - run of 1/0 to the back from my d6500 to the BT80. I want to add a D3100, an sk 85.4, one more run of each, and dual inputs for my setup. I know I'm going to need some battery terminals and want to make sure this is right so I can buy the correct ones from project db.....Please help me and let me know if my plans here are correct:
I appreciate any help....thanks.....
97 Suburban
8 custom PSI Platform 3 18's
Looks ok. Remeber to fuse each + run. Depending on where your rear batteries are in respect to each other you mights want to fuse the + between those as well - if they are fairly close it's ok.
To be clear, in your diagram I don't see fuses on the following:
  1. One of the + runs from front batt to rear I see it now, its not in a rectagnle like the other wire and that threw me off.
  2. from rear batt to skar 85.4
What type alternater do you have?
What type of 1/0 do you plan on running ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Thanks for your help! I'll add the fuses you suggested between the batteries and before the 85.4
My alternator is a Mike Singer 250a. My 1/0 that I have ran right now is welding cable, and I'm going to order 50 feet of OFC from Audio Technix.
Thanks again for helping me with my plans....time to order stuff!!!
97 Suburban
How far apart will your BT80 and D3100 be ?
if they are so far apart that they need a fuse then you will need a fuse very close to each battery for each run between the batts.Fusing in the middle would be near pointless.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 897 Guests (See full list)
