Lexan Window Questions
KenC210
1" clear rod from your window running between the subs should help. How thick is your plexi ?
The plexi is going to be .276" i think thats 1/4 a inch or so
If you are using 1/4" plexi, then bracing is the least of your concern. The plexi would be your weak point. I've never built a sub box with plexi, so someone else more experienced should chime in, but I have built shelving and other things with 1/4" and 1/2" plexi and in my opinion, neither is thick enough for a sub box with any power.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
Just use thicker plexi. Others here who are experienced in using plexi in boxes will come along any minute to give their recommendations on how thick it needs to be. The simple answer is as thick as you can afford. I would guess that 3/4" or 1" would be sufficient depending on what kind of power you are putting to the subs.
Two RE SX 18" subs
Just double up the 1/2 plexi for the window
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
  • Who's Online   0 Members, 0 Anonymous, 3081 Guests (See full list)
