Can't figure out what's wrong
Sup guys?
I have a bit of a problem with my home audio system.. i have a pair of cerwin vega xls 15's.. for about a year now.. the other day out of nowhere at about 1/4 the volume i started hearing like a crackling noise from the woofer.. it only happens when i turn the volume up and they're single voice coil woofers i believe.. i cant figure out what's wrong with it. I've tried using a different amp, so its not the amp, changed all the wires and rca's to make sure it wasn't a signal problem, and i removed the woofer out of the crossover connection and fed it straight bass signals.. none of solved the problem.. the weird thing is i have an older speaker which is fine and when i do the same i get the same thing happening.. but when i plug it into my other cerwin vega nothing happens..
any ideas?
2008 BMW 550i M Sport
Build coming soon!
2000 Volvo s40 1.9T
Pioneer DVD navigation head unit
O2 audio performance mid range speakers
2 Crescendo PWX-6 Pro Mid Range Speakers
2 Crescendo PWX-8 Pro Mid Range Speakers
4 Selenium ST200 Super Tweeters
Hifonics ZRX2000.4 Amplifier
2- 12 inch DC Audio Level 4 m2
Hifonics Brutus BXI-1610D Amplifier
2 KinetiK HC1400R- Secondary Batteries
Kinetik HC600- Secondary Battery
Knukonceptz 1/0 gauge big 3 upgrade
maybe you have a bad terminal on your box, try running speaker wire directly from the sub through the side of the box and to your amp to see if that alleviates your problem
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
but if its blown and its a SVC wouldn't it not play? also i smell nothing, see no burns and the coil doesn't seem to be damaged when i look at it from the side..
Build coming soon!
2000 Volvo s40 1.9T
I've taken the woofer out and ran wire straight to it.. it took a little more power but then the noise would come back.. i've noticed that it happens at certain frequencies more than others tho
Build coming soon!
2000 Volvo s40 1.9T
Push on the cone and see if it scratches. It could be something in the gap
If that's fine, I'd check all connections.
Any coil rub when pushing on cone?
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
No coil rub at all.. that's why i'm so confused! Everything seems to be functioning fine! I've never over driven these woofers.. and the power is pretty clean being that i run them on a crown amp.. i'm about to call cerwin vega and see if it's still under warranty.. maybe it's defective?
Build coming soon!
2000 Volvo s40 1.9T
The only thing I did not check is the actual power outlet.. but i don't think that would cause one channel to be dirty and not the other.. i'll try that first and see if that changes anything... doubt it tho..
Build coming soon!
2000 Volvo s40 1.9T
