load350z Posted September 25, 2012 Report Posted September 25, 2012 Wats up member, looking for some advice on how to setup the equipment i have (1) SMD D2 15inch. (2) Rockford T1500bdcp. Enclosure size unknown at this point any advice would help. This will be a daily pounder for my nissan altima. Im not sure if i want to run an amp to each coil or strap the amps together..im a newbie when it comes to wiring 2 amp to one sub. lmk wat u think would be the best route to go. thanks. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Mlcantin Posted September 26, 2012 Report Posted September 26, 2012 Wats up member, looking for some advice on how to setup the equipment i have (1) SMD D2 15inch. (2) Rockford T1500bdcp. Enclosure size unknown at this point any advice would help. This will be a daily pounder for my nissan altima. Im not sure if i want to run an amp to each coil or strap the amps together..im a newbie when it comes to wiring 2 amp to one sub. lmk wat u think would be the best route to go. thanks. Strapping would give the most power and will produce cleaner output
ALPINE408 Posted September 26, 2012 Report Posted September 26, 2012 Wats up member, looking for some advice on how to setup the equipment i have (1) SMD D2 15inch. (2) Rockford T1500bdcp. Enclosure size unknown at this point any advice would help. This will be a daily pounder for my nissan altima. Im not sure if i want to run an amp to each coil or strap the amps together..im a newbie when it comes to wiring 2 amp to one sub. lmk wat u think would be the best route to go. thanks. Strapping would give the most power and will produce cleaner output More power? Depends on how he wires itCleaner output?? That's a negative Have you ever had your woofers blown?
load350z Posted September 26, 2012 Author Report Posted September 26, 2012 i found out the cp's cant be strapped 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
will77530 Posted September 26, 2012 Report Posted September 26, 2012 for box help its going to depend on max dimensions you have to work with how you end up powering the subs what kind of music you like
load350z Posted September 26, 2012 Author Report Posted September 26, 2012 i would like to stay under 4cu..3.5 would be perfect. the altima trunk is pretty big. n i listen to rnb hiphop 95% of the time 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
