what is your budget?
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
2004 suburban subs facing up port facing the back door. kicker calls for a 3.6 cu feet box at 36hz but i like it a little lower. 2 kicker comp vr 2011 models on a kicker 1000.1 dx i like l ported box or whatever is simpler
jimmight
Hi I have a sundown 1500Dv2 for sale. If you are interested pm me. Here is the link http://www.stevemead...2-like-new-315/
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
I have an AQ750 for $140 local pickup if you're here in SoCal/ IE.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
whaaaaat?!?
and OP, with the 2515, i would get something that does 700-900rms at 1 ohm (if you have a dual 2 subwoofer). i would personally go with the AQ750 or something of that same caliber.
sub is dual 4 wired at 2 ohm if i purchased it from dd i would have bought dual 2 but i paid $100.00 dollars for it and a crappy box so i wasnt complaining the guy thought it was a 500 series and didnt have any clue from what i could tell. budget is curently about $200 cause i will have to run new power and ground to power a bigger amp even with only the curent 350 watts it is getting my interior lights dim
  • Who's Online   1 Member, 0 Anonymous, 1204 Guests (See full list)
