Teriowin Posted September 27, 2012 Report Posted September 27, 2012 Greetings from Venezuela Gentlemen My name is Noel Sanchez. I'm going to leave them a small project that we plan and see just what they see of us involved are Alberto, Custom, Daniel, Martin, Yamel, Javier, Mark and myself have the desire but we lacked the time Hairtricks in my country Venezuela is not Known. So this project is for that. What we want is to build a 4th order bandpass with 4 SUBS 15 "Orion XTRPRO154 and the amplifier for them will be one 5000.1D Powerbass XTA. Overall dimensions of the cabin Width 88 high 87 x 95 Prof. in (centimeter) With 18mm wood gives a little over 25 feet. As will be seen at the end, we hope so. Well, I can summarize as working a 4th order, of course, I'm not the most expert: 1) The area is sealed which gives the low 2) small sealed area requires more power because control q cones forward and back 3) small ported Area gives you a flat response and a big a box "barracuda" as you play with these sizes and depends on what you need 4) Pick a 4th order is near the area of intonation ported if 40 hz humming Andara peak around that depending on the radios that use. 5) Port for normal like a box ported, which depends directly on the parameters of the low 6) subs with a high QTS are most appropriate for a 4th order since they work better in sealed boxes. Very generally the explanation but it is understood Under Specification XTRPRO 15 "4ohm Fs (free-air resonance, Hz) 28.7 Vas (equivalent compliance, cu. Ft.) 3207 Qts (total driver Q) 0.73 Sensitivity 85.9dB Pe (continuous power handling, watts) 500 Peak Power Handling (music, watts) 1000 Mounting Hole Diameter (Inches) 13.85 Mounting Depth (Inches) 7.5 A Model of the box is made by sealing 1.9 and a radius under 1.9:1 XTA 5000.1D New design. I miss sealed divide the area into two then I do. 2 feet low net sealed. Ventilated area 20 feet in net 220 "to port. Radio 2.5: 1 future reinforcements + internal bracing maybe epoxy resin also Power: Kinetik HC2400, HC1800 Kinetik, Optima Yellow Top Photos of the subwoofers Looking for the best way to put the sub Taking measures Numbers It is planned 6-7 feet sealed And 15 the ventilated because we have 25 cuft descontanto wood we have like 22 available Well really hope to have your support in this project and have their experience The translation was using google translator so I hope we can understand Hairtricks in my country Venezuela is not Known. So this project is for that. We need some advice about tuning the box. As it will be for hairtricks we need to move air. Maybe We are Thinking 5-6ft sealed and the rest 18-17 cuft will be vented What is your Recomendation? Thank you in advance Firts time we make a bandpass so big Goodbye Noel Sanchez Venezuela Team Decibeleros 1er. Lugar en el 1er. Bass Race Categoria 135.9 -139.9 3er. Lugar 1ra. Copa Piques Decibeleros Categoria 135.9 -139.9 Caracas - Venezuela TEAM DECIBELEROS Subiendo Decibeles
Industrial_vnz0 Posted September 27, 2012 Report Posted September 27, 2012 ohh brother greetings, I hope the best of success and I am very aware of your project to make mine with 4 12 "obsidian .... expected to arrive here smd drives and can help you to the fullest .... I see those xtrpro to see if I copy ........ hahahaha
2loud4uboyz Posted September 27, 2012 Report Posted September 27, 2012 Welcome to smd sir. That looks awesome . Do you have anymore pictures of the subs Butt, they look very sexy sexy. Looks like you do some good work to. I will keep checking this thread. I'm tuned in. I think you will be moving alot of air.
Teriowin Posted September 28, 2012 Author Report Posted September 28, 2012 Photos soundproofing disarming Roof soundproofing agency friends Alberto, Martin and Mauricio soundproofing blanket for work installation Final work Batteries Kinetick HC1800 Kinetick HC2400 Optima Yellow using bassboxpro to see the tuning frequencies: and the port: what do you think? We don´t know if its better to put the magnets to the subs in the vented side of the box, so that the subs coils will be working cooler I think. Cause final configuration will be 0,5 ohm + impediance rise. but each sub will be receiving: 1200rms +/-. Is the box OK? Any suggestions? Thanks for your feedback 1er. Lugar en el 1er. Bass Race Categoria 135.9 -139.9 3er. Lugar 1ra. Copa Piques Decibeleros Categoria 135.9 -139.9 Caracas - Venezuela TEAM DECIBELEROS Subiendo Decibeles
fecupe2001 Posted September 28, 2012 Report Posted September 28, 2012 damn venezuelans!!! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Turn it up Posted September 28, 2012 Report Posted September 28, 2012 fecupe give them some advice lol you're the man! Suben videos cuando acaben con el proyecto saludos desde CA .
fecupe2001 Posted September 28, 2012 Report Posted September 28, 2012 hahaha ellos son amigos mios desde hace años, no creo que necesiten mucha ayuda, saben bien lo que estan haciendo I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Teriowin Posted October 11, 2012 Author Report Posted October 11, 2012 soon more information Thanks 1er. Lugar en el 1er. Bass Race Categoria 135.9 -139.9 3er. Lugar 1ra. Copa Piques Decibeleros Categoria 135.9 -139.9 Caracas - Venezuela TEAM DECIBELEROS Subiendo Decibeles
LBM Posted October 11, 2012 Report Posted October 11, 2012 It looks real nice people all over the world building rides which do hair tricks !!! And thanks to Steve to bring them to a common platform via his forum !!! http://lbm.net.in
Teriowin Posted October 22, 2012 Author Report Posted October 22, 2012 Photos Work Weekend 1st Day Photos disarming Terios Insonorizando Mas el Techo It Starts Arming The Box 1er. Lugar en el 1er. Bass Race Categoria 135.9 -139.9 3er. Lugar 1ra. Copa Piques Decibeleros Categoria 135.9 -139.9 Caracas - Venezuela TEAM DECIBELEROS Subiendo Decibeles
