box help!
AK bass
I am building a box for the first time. My dimensions are 48"w 35"h 28"d @ about 30hz for two kicker 10s on a 1000.1 (i know kicker isn't the best) thanks in advance.
"The secret to creativity is knowing how to hide your sources." Albert Einstein
Seriously missing infos there, what subs, amp vehicle models do you have, what's your goal with your setup.
2004 suburban subs facing up port facing the back door. kicker calls for a 3.6 cu feet box at 36hz but i like it a little lower. 2 kicker comp vr 2011 models on a kicker 1000.1 dx i like l ported box or whatever is simpler
Ok here is a suggestion:
Enclosure Specifications:
Fb = 33 Hz
Vb = 4.3 ft^3
External Height = 15 in
External Width = 38 in
External Depth = 22 in
Port Width = 4 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Top & Bottom = 38 x 22
Left & Right Sides = 20 1/2 x 13 1/2
2x Front = 16 3/4 x 13 1/2
Back = 38 x 13 1/2
Shared Port Internal Assembly Parts:
2 x Front to Back = 18 1/4 x 13 1/2
2 x Extension = 2 7/8 x 13 1/2
Assembly guide (generic dimensions):
Let me know any questions.
looks great I will start building asap! :D
20120929_074012_zps4dab2489.pngits all done and sounds great thank you Joe X
Next time, if you're in Alaska, feel free to hit up North Coast Customz
  • Who's Online   0 Members, 0 Anonymous, 680 Guests (See full list)
