why would a waterpump break like this!?!?!
No not the head? The waterpump it self.when you buy a new one it don't come with a pulley Ibought it new put the pulley on. There's 4 bolts that scew threw the.pulley into the pump.they snapped and grade.of bolts idk.stock ones?
I mean the heads of the bolts. I also thought you broke the entire water pump off the block lol
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
The snapped clean off all 4 of them. And idk if they backed out Never checked them. I did a final check before I started her at all this morning. Everything checked out fine and ill be sure to do that tmw when I get it fixed found the pullly its fucked.Ithink its what caused the bolts to break.ill get pics tmw
Did you use loctite on the pulley bolts or not? Pulleys don't cause bolts to break. I've seen bent pulleys, broken belts, misaligned pulleys, etc, but none of them ever broke a bolt. Bolts backing out would cause that kind of carnage, just a matter of time.
Loctite? Yes or no?
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
Either the pulley was warped or you tightened the bolts to damn tight and then once it got hot and load on it snaped them.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
I didn't use lock tite. on those bolts I didnt think I needed to but its a lesson learned everyone makes mistakes.which mine was a a big one
Isaid in my first post I didnt tighten them to tight. when I asked
.ohhh hahaha yeah the head of the bolts broke off lol my bad! It was probably what everyone else is saying the must of backed out.a bit and the pulley couldn't hold the load. broke as you can see in the pic of the pulley and took the. heads with it and cause some other carnage as well
Ok then. I'm not trying to bust your balls, just that it seemed to be the most likely culprit based on your description. If you didn't use it, then I'd say about 75% chance that was was happened. Like you say, lesson learned. You'll know for he next time. I once left the intermediate shaft of the oil pump out of an engine I was assembling late at night. Had about $8000 invested on an engine I had built completely by myself. Fired the engine up and ran it with no oil pressure during breakin. Had to rebuild it all again. Shit happens.
Two RE SX 18" subs
What is that pulley make of? Did you use a torque wrench you know they weren't too tight, that is what I was getting at, I have tightened plenty of bolt I thought were fine and then snap off cuz just too tight.
Evo X build log
