why would a waterpump break like this!?!?!
Ohhh I'm sooo pissed! I finally got everything done motor and drive train wise.fired her up broke in the cam and then.drove her around.for a hour or so then parked it.but then just went to take her out to o street " cruising" road on fridays and saturdays.well got to about 27th and o. And everything goes wrong! Water pump pulley.broke! Well the bolts did and it was a new water pump! Dk why! Didn't tighten them to tight at all Well since that broke it snapped the belt.which the belt cut the hoses and battery wires and bent the alt pulley and fucked my fan up! Ughhh! That will riun a night by far! Its on my mustang.built motor didn't even get to dyno! But a guess 450 to 500hp
Pics would help, but it sounds like maybe your belt was too tight? Is it a v-belt or a serpentine? Either that or your idler seized up if it is a self-adjusting serpentine. Could be quite a few things, but pics would help.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
It didn't break the wire it pulled it right out of the clamp.and pic ill try to get tmw.when its light out and its a serpentine belt
Break the heads off? What grade bolts?
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
No not the head? The waterpump it self.when you buy a new one it don't come with a pulley Ibought it new put the pulley on. There's 4 bolts that scew threw the.pulley into the pump.they snapped and grade.of bolts idk.stock ones?
Did you make sure to use loctite on the water pump pulley bolts? Nice, clean new bolts will quickly work their way loose if you don't use loctite on them. You HAVE to use loctite blue or red. Once one or two bolts back off slightly, it isn't long before the pulley wobbles and the bolts break off just under the head. That'd be my rudimentary guess without seeing pics. Either that or your idler seized up, but usually that will just snap your belt, not affect your pulley or break bolts.
Two RE SX 18" subs
Seen this happen on a couple of built 6.4 Powerstroke trucks, and a badass 6.0 TT truck that snapped an alternator bracket. Loctite on the bolts will keep them from backing out so quickly.
This would be my guess bolts came loose causing a greater load on the bolts then it was a matter of time before they broke. Damn beat me to the punch. ^^^^
Did any of the bolts back out or did it snap them all off clean?
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
