DC 8's 4 channel dvd deck
got basically BNIB dc 8's taken out to use as mid bass in doors didnt work out so they have less than an 1 hour play time with like a 100 watts
250 for the pair shipped
next to a lvl 2 10
cosmetically 9/10 1 point off for being mounted before
mech 10/10
Next stetsom th 4120
cosmetically 7/10
mech 10/10
125 shipped
specs
Channels 4
Potency PMPO 1800W
RMS Power @ 13.8V
STEREO 4 Ohms 4 x 80W
STEREO 2 Ohms 4 x 120W
BRIDGE 4 Ohms 2 x 240W
Consumption 0,6 a 56A
Input Tension 13,8V
Frequency Response 15Hz a 50KHz
Signal to Noise > 90 dB
Input Sensitivity 0,2 a 6V
Total Harmonic Distortion < 0,2%
Input Impedance 50 K Ohms
Output Impedance STEREO 2 Ohms
Output Impedance BRIDGE 4 Ohms
Damping Factor > 400
Lo Pass 40 a 700Hz
Hi Pass 70 a 700Hz
Dimensions 45 x 240 x 422 mm
Weight 3,6 Kg
i have a cheap DUAL dvd deck
cosmetically 7/10
mech 8/10
75 bucks shipped everything works dvd e brake has been bypassed just needs a little help ejecting cds
here are specs no i plug
http://www.sonicelec...l-XDVD8181.html
will add more later
i am a super seller no name and date needed
bump it up with dc 8 specs\
Mounting Depth
5.25"
Mounting Hole Diameter
7.25"
Motor Width
6.5"
Weight
17.5lbs
VC Diameter
2"
Displacement
.10³ ft
Magnet Weight
15lbs
Power Handling RMS/Peak
300/600
Impedance (Ohm)
d2 or d4
Sd
201.93 cm²
Vas
7.01 L
Cms
126.134 um/N
Mms
157.47 g
Fs
35.71 Hz
Bl
15.29
Re
3.95 ohm
Qms
4.64
Qes
.59
Xmax
16.5 mm
Sensitivity
79.04 dB
Suggested Sealed
.5³ ft
Suggested Ported
.8³ ft
Coils on the 8's?
