Sub amp compromising head unit speakers
Installed a memphis 500 watt rms monoblock amp in my buddies toyota corolla. I wired everything standardly how it should, clean and proper; but when attempting to turn up gain or playing subs at a high volume, the rear 6x9 speakers that are connected to the head unit distort majorly as if the amp is giving them as massive amount of bass. I double checked all the wiring, even re-routed a ground; and still no luck. does anyone have any ideas on why the 6x9's are picking up a bad signal? maybe a bad HU?
do you have a high pass set for the mids so they dont get anything low, id set it around 60-80hz, they are probably getting tons of lows, or it cause your having a voltage drop and when that happens the headunit outputs less power to the speakers, so its clipping every time the sub is playing loud when you you have everything hooked up.
Try this: unplug the positive subwoofer wire so the subs wont play, then play it like you were does it still distort the 6x9's, this will leave the amp in the equation, but it wont be pulling really anything for amps, also check your voltage when the sub is playing loud, see how low its going?
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   0 Members, 0 Anonymous, 5490 Guests (See full list)
