So I have a supercharged 9515h and I'm running it off my M2a (2500rms) which is powered by an xs power XP3000 and stock alt. I've had it playing for about a month and yesterday was the first time I had a problem, I was playing it and the sub started cutting out/playing weird. I dont really know how to explain the way it was playing other than it sort of sounded blown. It plays fine until it gets loud and starts to clip a little, then it does this. Also the amp stays on this whole time and does not go into protect mode.
the sub reads a steady .9ohm
battery doesn't drop below 12v
checked all connections
tested at multiple frequencies
subs suspension seems normal
So my question is, does anyone know what is happening, whats causing it, and/or how to fix it?
Any help is greatly appreciated
2007 Toyota Corolla
Sub:
DD M3c
DD 9515h D4 wired to 2ohm
Mids:
DD A2 (2)
DD VO 6.5 (4)
Power:
Js 180a alt
XS D1200
XS XP3000
XS XP975
XS 1/0 OFC (Big 3)
XS 1/0 OFC (2 runs pos/neg)
Sky High machined set screw battery posts (all batts)
Score:
Never metered
I hope you have at least a single run of 1/0 power wire from the front battery back. Now which battery are you referring at doesn't drop below 12v, the XS?
Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!)
Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2
Speaks: RF T2652-S 6.5" and RF T1692 6x9"
Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's
Wiring: Kolossus Fleks Kable 1/0 (2 runs)
one run of 1/0 and yes the xs
2007 Toyota Corolla
Sub:
DD M3c
Mids:
DD A2 (2)
DD VO 6.5 (4)
Power:
Js 180a alt
XS D1200
XS XP3000
XS XP975
XS 1/0 OFC (Big 3)
Score:
Never metered
Read the voltage right at the amp inputs, even if all the connections might look good, they might not be. Just another way of knowing for sure it isn't your connections.
I've read the voltage at both the battery and amp already, both read the same
2007 Toyota Corolla
Sub:
DD M3c
Mids:
DD A2 (2)
DD VO 6.5 (4)
Power:
Js 180a alt
XS D1200
XS XP3000
XS XP975
XS 1/0 OFC (Big 3)
Score:
Never metered
How is your amp set
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
How is your amp set
gain is about halfway, lpf is at 120hz, subsonic is at like 30hz I think but I'm not positive on that right now I'm in school, and bass boost is off
2007 Toyota Corolla
Sub:
DD M3c
Mids:
DD A2 (2)
DD VO 6.5 (4)
Power:
Js 180a alt
XS D1200
XS XP3000
XS XP975
XS 1/0 OFC (Big 3)
Score:
Never metered
whoa 120?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
K so you don't have your gains set right. Your lpf is pretty freakin high. How about your ground? Where is it and have you tested for resistance?
under construction
u hate c-fizzy?
  • Who's Online   1 Member, 0 Anonymous, 1288 Guests (See full list)
