UPDATE..!!! TAHOE DC LEVEL 3 15s box build
next time fiberglass and mat! Keep ur airspace and make it even stronger than the 45's. but yes those kerfs look good.
Sorry to keep critiquing but we are on here to show off and learn.
Just a suggestion, you can body fill and sand the kerf before you paint to leave it absolutely flawless and you do not see the ridges of the kerf
yeaa i get you man but right now money is very tight and at age 17 i dont have much to spend jaja but ive been reading on here for a while and have learned soo much!
and hey no worries man i aprecciate the critique its wat helps me get better. and as of the body filling that is exactly what i had planned on doing..every seem on the outside of the box will be filled with body filler :)
Nice you're box is gonna be super cleaaaaan
thats the plan man!
-2000 chevy tahoe 5.3 liter v8
-two DC audio level 3 15 inch subwoofers
-2 pairs of infinity kappa 60.9cs components
-rockford fosgate t1500.1bd for subs
-rockford fosgate t400.4bd for mids and highs
-alpine deck
-big 3 upgrade 0 gauge power cable
-optima yellow top battery
-custom made subwoofer enclosure 6 cubic feet tuned at 35hz
Nice job man! Did you do your own design or did you have it done for you and you made it?
i had the general idea of the box but the credit goes to joe x for designing it for me he was a huge help in this.
-alpine deck
Do you use screws at all to put yours boxes together?
i usually just use air gun nails glue and clamps. but for this one i will put screws on the baffles
-alpine deck
looking good!
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
looking good!
thanks
-alpine deck
today i only got my kerfs and covered them in body filler i had about 45 min to work so thats all i did. sanded one of them down almost smooth. still needs more sanding but heres the update for today
this is by far the best body filler i have used. i have not seen it in stores before, at my dads job there are tons of these and im guessing they are for industrial use.
-alpine deck
yeaa so far its the best one ive used.
-alpine deck
today i sanded down one of the kerfs smooth and added three coats of primer to it. not much at all because i need to go get some more primer and sandpaper to finish the other kerf
this is after the first coat. you can see how the wood absorbs the primer.
after third coat and some wetsanding with 600 grit
-alpine deck
Awesome progress! Can't wait to see more
2008 Black Chevy Tahoe -Murderedout/ 2/4 Belltech drop/26" U2-55's/ HID's in fogs and headlights/G5 tails1 - BC35001 - C1100.42 - SA ZV3 18's6 - 8" SA Neo Pro's2 - FT1-SE Tweets
