I've never used sound deadening of any kind, and this upcoming week I will be using damlifier pro on my trunk. I know I need to clean the metal surfaces before I apply the material, any suggestions on solutions? Does rubbing alcohol work well? Also, any tips/tricks I should be aware of for the areas I need to leave uncovered, like the rear deck speaker cut outs or where the wiring harnesses/screws need to be coming through the material??
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
Those cuts hurt lol
Yeah I cut my hand up while carpeting my box, shit sux haha. And I will post anything relevant that I find. Shold ii Cut the holes out before or after applying the damp? Just wondering cuz I know its hard to tell where to cut before its rolled/pressed down permanently...
Subs/Amps: TBD
What I did was take my sheet of damp that I was about to lay, then before taking the backing off press it against the surface to form and any spots that stick out would press a little bit of a form into the backing, cut out at those spots to avoid covering wire mounts and stuff.
I thought that getting cut was a sign you were doing it right, lol. Guess i should buy some gloves. I used soap and water then followed with alcohol and i wasn't drinking it this time.
  • Who's Online   1 Member, 0 Anonymous, 1288 Guests (See full list)
