Justscrap Posted October 8, 2012 Report Posted October 8, 2012 Wassup fellas? I'm looking to build a box for a single kicker L7 12 that I have sitting around. I'll be using a JL audio 500/1 to push it. I know that's not much but I also only have stock elec. I have a second 500/1 if necessary,but i think it will strain the stock elec. so that was my reason for only using one of the 500/1's. I will be putting it into a 2006 Pontiac Grand Prix. The space I have available or where I put it,have the measurements of: 30"-33" width......18" max height....and 13" max depth.... I've looked up a few boxes on diff. Websites online and some people say use kicker specs. And others say not to. I just want something efficient with the power I will be using and I listen to all types of music. Not looking to compete but would be nice to get loud as possible with what I have. And again I'm only using what I have laying around and decided to do a small build with it so any suggestions or opinions would be appreciated!! Thx fellas! For my h/u I have alpine 9885,doors:morel comps.(front),fosgate 6x9's(rear) all powered by a JL 300/4. if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Spencer Good Posted October 8, 2012 Report Posted October 8, 2012 Why would you ever NOT use the manufacturers specs? Come on man.. 2012 TORed Challenger 4 Alpine Type-R 10 1 Brutus 2400.1 20' Knu 1/0 OFC 1 XS Power D1200
AI James Posted October 8, 2012 Report Posted October 8, 2012 2.5 cubes 38hz 15 per should be decent for that sub
Justscrap Posted October 8, 2012 Author Report Posted October 8, 2012 Thx F.A.....anyone else have any ideas or suggestions? if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Joe X Posted October 8, 2012 Report Posted October 8, 2012 Here is a suggestion within your dims, on the efficient side: Enclosure Specifications: Fb = 34 Hz Vb = 2.7 ft^3 External Height = 18 in External Width = 33 in External Depth = 13 in Port Width = 2 1/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 33 x 18 Left & Right Sides = 11 1/2 x 16 1/2 Top & Bottom = 33 x 11 1/2 L Port Internal Assembly Parts: Front to Back = 9 3/8 x 16 1/2 Extension = 11 1/4 x 16 1/2 Assembly guide (generic dimensions): Let me know any questions.
Justscrap Posted October 8, 2012 Author Report Posted October 8, 2012 Thank u sir! I'll hit u up if I need any questions answered...any other suggestions or designs fellas? Thx again! if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
