(4) Zv3 12s - 5k - Project Nasty No wall
Did a little testing. Pretty damn cold. In the 20's air temp.
Did a 151 Legal. Doing nothing to the truck/orientation. Just folded seats and went. Not bad, but not really happy since i lost about .8db in terms of efficiency from my old box/SA's. Makes sense, but I'm still going to try to get that back.lol. Clamp results are as follows
Wired .5 Nominal (one amp)
-62.5 ACV
-42 ACA
-2625w @ 1.48ohm
-Starting voltage = 14.4V
-Lowest Drop ~13.8V
1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
Nice numbers man. Are those just reg. off the shelf Zv3's or did you have anything changed in them?
I bought these with 2 NSv2 Spiders instead of the stock Zv3 pack and the NSv2 cone/surrounds. I have no idea if these are even helping
Looks real clean man
06 Trailblazer ss
2 Team shok industries tsx 18s
Phoenix Gold ''THE ONE''
2 Phoenix gold 800.4
4 crescendo mp6.
2 crescendo mp8
bass processor
Dc power 270xp
150ft 1/0 ofc sky high cable
1 juicebox lithium 0.5kwh 14v/40ah
kenwood dnx8120
BCAE1.com
YouTube channel : REaudioxxx1
build log: http://www.stevemeadedesigns.com/board/topic/160106-trailblazer-ss-xxx/
Cool box! It's set up the same way my new box is set up. I'm using 2 Fi Q15s and a 10in. aero port. Qs are not spl subs so I don't expect big numbers.
You're lucky you have so much room for battery and amps. I have to ditch my spare and hide everything under a false floor. It's a tight fit.
Keep it up! Post more vids!
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
Appreciate it man.
I really dont have much room. That box is barely 6 cubes after displacements. And the distance i have to the hatch is where it's been loudest in the past. But non the less it seems to work. Thanks for checking it out. More vids when I get that other amp in there
How far is it from the hatch, if you don't mind me asking? Mine is going to be 7-8inches away. My box is 7.1 after displacements.
its about that. not all vehices behave the same in this regard. I just tested and that spot was best. I'll have to retest or at least reconfirm that spot now that I've changed port layout
  • Who's Online   0 Members, 0 Anonymous, 1816 Guests (See full list)
