Im going to make a alpine home theater set-up. I know home theater runs normally off 8ohms but i found a couple recievers that accpet 4 or 8 ohm spearkers. my question is how big do i need to make the enclosure for the componets. i havnt decided on 5.25 or 6.5 yet i wanna do one componentset per box and 2 for the center channel. what i need is box demission. made out of 3/4 mdf any help would be good alpine dosnt suply this info on there website.
looks like you have a goal set for you there..
Pretty interesting.
I would say though that the component speakers really wouldnt require that big of boxes, if you keep in mind, they dont run bad in "free-air" but if your making towers just make the towers wide enough for the speakers and with depth it depends if you'll be porting your low frequency speakers.
In my opinion, the boxes for the mid's high's do not need to be that large. If you have seen the prefab boxes for like 6x9's you'll see that you really dont need whole lot of box for those.
However if you plan to mix in a mid-ranged low-ranged woofer in there you'll need to get the specs right for porting that sub or mid-ranged speaker
Edited by AlpineGuy87
06 SCION tC
I havnt decided from TypeR or TypeX yet. Im going to use 10" or 12" subs havnt choosen yet. Next quest how to shield the subs and speakers from harming the TV. center channel will be above tv and sub box was gonna hold the tv as a stand.
Components
SPR -17S
http://www.alpine-usa.com/US-en/products/p...p?model=SPR-17S
SPR-13S
http://www.alpine-usa.com/US-en/products/p...p?model=SPR-13S
SPX-13PRO
http://www.alpine-usa.com/US-en/products/p...model=SPX-13PRO
SPX-17PRO
http://www.alpine-usa.com/US-en/products/p...model=SPX-17PRO
Subwoffer
SWR-1242D
http://www.alpine-usa.com/US-en/products/p...model=SWR-1242D
SWR-1042D
http://www.alpine-usa.com/US-en/products/p...model=SWR-1042D
SWX-1243D
http://www.alpine-usa.com/US-en/products/p...model=SWX-1243D
SWX-1043D
http://www.alpine-usa.com/US-en/products/p...model=SWX-1043D
Edited by scarykds01
I have been looking at all these premade systems they all say 5.1 6.1 7.1 and they all have 5 speakers and 1 sub whats diff about these systems pros and cons was woundering.
5.1 is just basically your left, right, center (aka FRONTS) and then the other 2 are your Left Surround and Right Surround (positioned side of listener) then you have a Subwoofer.
6.1 could be an additional Rear called Center Rear (position directly behind listener
7.1 is Just like the 5.1 setup but with 2 extra Rear aka Left Rear and Right Rear. (positioned behind listener)
Here are examples of each...
06 SCION tC
keep in mind you'll spend like tripple if not more on making this system setup because you need power inverter/converters to go from 120v to 12v and you have to have the right powerlines and proper amps and reciever to power these speakers.
The box build will be the easiest and cheapest part to do but without the proper tuning it wouldnt be worth it at all.
06 SCION tC
Why would you need a power inverter? for the highs some recievers take 4 ohm loads. and for the sub i highly recomend buying a plate amp as they are called. look at these: http://www.partsexpress.com/webpage.cfm?we...ectGroup_ID=505
I got 1 pioneer 12" running off a plate amp and the box i made my self and finished it nice. and it is by far the best powered sub ive herd for only 175 that i put into everything for it. And you would not want to run a 12v amp to them anywase, it would just be to much work and a waste of money.
Edited by Clif
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
Also check out Partsexpress.com they have a whole diy speaker building section.
In Dash
Rear Flip Down
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
