Cost Saving Idea
I had an idea but I wasn't sure if it was correct. The original set up: stock 650CCA battery, stock 4awg wire on the stock 130a Alt., big 3 (all 1/0awg), two positive and two negative 1/0awg runs from the main to the back battery (let's say a kinetic HC2400).
My idea is to instead of running the two batteries in parallel (or inline at all) keep the stock battery alone and run a positive and negative 1/0awg run directly from the Alt. to the back battery with a inline isolator. This would separate the two systems and allow you to run the back battery dead and still start up the car on the first try? Also this would only require one run (if that) of positive and negative 1/0awy because it would only run up to 130Amps at a time. This would be cheaper because you would not need to do a big 3 or buy multiple runs of 1/0awg? Any comments?
You would only have to run maybe one 4awg positive and one 4awg negative from the alt to the back battery, not 2 1/0awg positive and 2 1/0awg negative
If you want to put a battery in the back and eliminate any runs to the front, just runs to the back... if that battery can't handle the system? And you need 2 batteries in the back? Guess what? Why buy another battery when YOU HAVE ANOTHER IN FRONT? Lol.
Look at the best in the world, their setups. They won't run 1 battery for the vehicle (startup and such) and a bank of batts wired separately from the front batt. It will be all wired together in some sort of fashion.
Sheena = pedobear
Running a battery till its dead just seems like it would end up costing you more to replace the abused battery.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
but then you would need more batts in the back to get the same amount of power last i checked wire was a lot cheaper than a batt and a isolator
and you will still lose on output
I like the thought process... thinking of things. But this is one of those things where you just don't fuck with what works. If you need 2 batts cause you have at the very least a decent system? Wire that shit together. Don't try to be slick and keep them in a sense, seperate.
And that should be the end of the thread. Haha.
Sheena = pedobear
  • Who's Online   0 Members, 1 Anonymous, 579 Guests (See full list)
