kicker solo x discontinued?!?!? wtffffffffff
AllanLuberda
The fact that you are so caught up on those numbers impresses me. True, the specs are slightly different which can indicate various ways a driver may react. The bottom line is that the most subtle change in an install can drastically change the outcome enough that those numbers are nothing but a vague at best indication towards how it will perform. Also, things like the glue can be changed on any woofer! If you pay the difference, you can get your woofer built with a 2part epoxy that will out perform the standard CA glue. Also, things like Xmax is absolutely irrelevant unless you are playing the level 6 at 31.5mm and struggling. It is very rare for somebody to actually reach the BL or mechanical limits of a driver. By far, the most common failure I've seen is blown tinsel leads or where the lead runs down the former from bad signal creating excess heat.
Like you said, both woofers are great and I'd like to play with either one. Just don't base your whole argument on the specs while adding your own guesses like longer coil and a "patent pending" former glue you know nothing about! But then again, you would want a massive stack of useless slugs and fully intends to destroy your own woofers.
-Drew
well Like i said I fully support both brands, DC is the shit hands down, I wasn't trying to bash dc at all. I simply stated the specs of both the sub woofers.The specs are the one thing you can really go by when buying a sub (Not the brand name) or enclosure you haven't even built yet. I also agree the slightest change in an install CAN have large effects. I also agree and am aware that subs rarely reach bl, but regardless the limits of the sp audio sub is superior, even if your willing too admit it or not. But how do you have any idea I am guessing. It is a fact that aluminum coils are USUALLY longer due too the lower resistance. The former glue is also not just a guess your wrong. I have spoken with the owner of sp audio with many many conversations on the subject, the stuff they use to hold the coil too the former is NOT like the rest of the glues every other sub company uses. It is the only reason I could explain an aluminum coil of the same size out performing a copper coil (other than the ventilation design leading to the pole vent) and possibly some other small factors.
The 5th magnet for the sp audio sub would be minimal yes, But that isn't the only reason, I should have stated I would realllly enjoy the simple wow factor of a 5th magnet and possibly a little extra room for the coil, making it slightly harder too bottom out. Maybe even a very small increase in s/n ratio... I do not have full intentions of blowing my woofers, but when you have both subs over powered due too a false rms rating from kicker shit happens..
My conclusion is that, the only one making guesses would be you. everything I stated were simply specification FACTS, I did not guess on the coil resin used, Explain too me how wanting spare re cones available has ANYTHING too do with what i stated in the comparison of the two sub woofers. I am pretty sure your just guessing I'm guessing and making shit up, I'm not...
Personally beefing up magnets and coils will only go so far... That is my (guess). why not simple increase the durability of the main thing that tends to give up in a sub woofer, and that is the adhesive that lets the coil slip off the former under extreme thermal conditions...Too me that is genius is it not?
I have seen far more coil former/separations than tinsel leads shorting out, though I have seen both happen. But fixing the most common failure in a sub woofer would be the most efficient fix...I dunno thats just me.
You call psi about a quote our what??
They can take care of you and your solo X's..
Let us know what they say I'm interested.
No i have not called psi yet, but plan too :-)
I have called kicker, they said the discontinued it due too the hard time they are having getting orders from the people who build the solo x's.
But ill let u know after i call psi.
i dident read a single post in here besides the op and the very last post.imo kicker is over priced garbage,sure a couple of there subs are OK.but other than that i wouldent waste my time with kicker.i mean shit they sell it at wal-mart now..i say find some baskets that fit the motors and then get ahold of psi,im sure they can make you something up.i just reconed a power hx2 15 with a psi drop in recone and it sounds amazing and gets loud as fawk
xbox 360 gamertag-greenrocks420
Not insulting you or anything, but did you just call us "bloody winging fairies" ?
Check Walmart.
hhahahahahahahahahahahaha awesome comment
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
dude go on ebay, tons of recones there and a lot of ebay stuff has free shipping
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
no need to tear out the wall. just change the baffle :fing34:
I was debating on that but mannnnnnnn do u have any idea how many screws and tubes of glues are in that baffle?!?!?!
least 200+ screws and 3 tubes...
I might be able to get it out, but omg itd be a biiiiiiizzznnnniiitttchhhhh
the baffle was engineered too firmly support 206 pounds of weight.
oh yeah and i fiberglassed the shit out the inside of the baffle.
Ive been there bro. I got a trunk car, and my boxes have been built in the trunk. its sucks but its part of the game. Think positive
BTW ive had soloX
and the only way to get box out
all this destruction becuz of the discontinue of solo xs?
No I ran them for a year then went to another brand. I had 2 10" SoloX on 2 ZX2500.1. got them to do a 50 out of my trunk.
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
  • Who's Online   0 Members, 0 Anonymous, 539 Guests (See full list)
