OrionStang Posted October 19, 2012 Report Posted October 19, 2012 Just wondering how much horsepower my 270XP kills compared to the stock 130. I know it depends on draw, amp is drawing ~80amps max. Is there even a way to know? SMD Super Seller My Feedback Thread
HunterJohnson Posted October 19, 2012 Report Posted October 19, 2012 i couldnt tell you but way to check is dyno with the 270xp then dyno with stock. I couldnt imagine it would kill much unless youre using more electrical than stock Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
Nate Futuristic Posted October 19, 2012 Report Posted October 19, 2012 i doubt there is a way to measure it without a few dynos (stock vs h/o im sure a few runs would show the difference) i assume it has a larger pulley than a stock alt so a few hp may be lost but not much or worth the $$ to get it dyno'd anything really belt driven will take away hp so if you want it back start reducing weight of other rotating masses down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
HunterJohnson Posted October 19, 2012 Report Posted October 19, 2012 i doubt there is a way to measure it without a few dynos (stock vs h/o im sure a few runs would show the difference) i assume it has a larger pulley than a stock alt so a few hp may be lost but not much or worth the $$ to get it dyno'd anything really belt driven will take away hp so if you want it back start reducing weight of other rotating masses h/o alts usually have smaller pulleys for over drive Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
OrionStang Posted October 19, 2012 Author Report Posted October 19, 2012 So its pretty much negligible. Especially with the other mods going on. I am just trying to make conversation for the next three hours. No work tonight, but trying to keep the same sleep schedule. SMD Super Seller My Feedback Thread
kalilac619 Posted October 19, 2012 Report Posted October 19, 2012 Lucky for you I've actually tested this back when I was in to street racing,car was a 94 honda accord 2 dr with a JDM H22 in it making about 220hp all motor at the wheels alt pulled only a 1/2 an hp if that under normal load that's with after market MSD ignition which pulls slightly more then stock now under full load ,head lights on ,interior lights on fog lights , and stereo on half volume which at the time was an alpine 5 channel 75 x4 and 500 x1 80amp fuse all channels driven lost about 5hp max at the wheels it varied but highest was 5whp alt was only 80amps being spun by a 4 cylinder so in ur case it might be alight different since your is a v8 with more torque might not be as severe ....hope that gives you an idea 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
OrionStang Posted October 19, 2012 Author Report Posted October 19, 2012 Lucky for you I've actually tested this back when I was in to street racing,car was a 94 honda accord 2 dr with a JDM H22 in it making about 220hp all motor at the wheels alt pulled only a 1/2 an hp if that under normal load that's with after market MSD ignition which pulls slightly more then stock now under full load ,head lights on ,interior lights on fog lights , and stereo on half volume which at the time was an alpine 5 channel 75 x4 and 500 x1 80amp fuse all channels driven lost about 5hp max at the wheels it varied but highest was 5whp alt was only 80amps being spun by a 4 cylinder so in ur case it might be alight different since your is a v8 with more torque might not be as severe ....hope that gives you an idea Cool, Noah. I shouldn't see any difference then(couple HP). Especially with the new parts going on. Thanks. SMD Super Seller My Feedback Thread
Nate Futuristic Posted October 19, 2012 Report Posted October 19, 2012 i doubt there is a way to measure it without a few dynos (stock vs h/o im sure a few runs would show the difference) i assume it has a larger pulley than a stock alt so a few hp may be lost but not much or worth the $$ to get it dyno'd anything really belt driven will take away hp so if you want it back start reducing weight of other rotating masses h/o alts usually have smaller pulleys for over drive O_o why was i thinking a larger pully makes it spin faster lol either way the hp lost wont be slowing your 1/4 or 1/8 mile times down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
kalilac619 Posted October 19, 2012 Report Posted October 19, 2012 Yeah it's not noticeable at all ....no prob man! 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
