ICE ICE POLO (ROBolop Design)
you are a madman lol. that little block with the bearing is a piece of art
EDIT: well...*those* blocks haha
really awesome to see a new project from the legend
THX Dude's.
This will be the box, that will be mounted in the trunk.
The 4 holes you see are for the Focal subs (4x13cm).
Another look at how big the sub-box will be.
Now you see a MDF-shelf that will part the sub-box from the amplifier area.
About the partition, I’m thinking on some cool things, but I’m not entirely sure yet…
First I had the idea to work in the equalizer in one of the sun-blinders on the seiling, but they were too big for it. It’s a pitty, cause I liked the idea myself.
Now I’ve been working on the amplifier, and the more I see it, the more it grows on me.
I’ll have to make a new sort of high-tec bracket, but that shouldn’t be a problem I guess.
Here you can see it’s possible that I raise the equalizer a couple of more cm’s, and that too I liked!
As for the finishing inside the box, I chose 2mm thick aluminium.
I also let some folding work done, which is strong.
Milled out the holes for the subwoofers.
Mounted the speakers for the first time.
4 in a row
Because I’m going to mount the equalizer onto the amplifier, I decided to make an aluminum plate.
First of all I drew out everything on a piece of MDF, 8mm thick.
The MDF will serve as a mold for the actually alu plate.
Here you can see how I started.
The piece is finished, and I’m happy with the result.
I sawed out the alu plate with the jigsaw, after that I taped it on the MDF.
Then I started to mill this with the copymill.
The result:
I just need to sand the edges…
Then I mounted the EQ on there with 4 screws, and layed it on the amplifier.
The busses won’t stay as in this setup. I’m going to let some made on the height I want.
Here you can see the amp also stand on “busses”. I did this to work away the cables.
For the first time, I timed how long I worked on this Aluminum plate.
Drawing on MDF
Mill the MDF
Saw the Alu
Mill out the alu
This all took me about 5 hours…
But as you guys already know, I don’t give a f*k how long it took me, as long as the result is OK for me
