Guest Posted October 19, 2012 Report Share Posted October 19, 2012 I let some one wire my stuff it has 4 gauge power to a block then 8 gauge to scar and 8 gauge to highs amp fix. it. now. 0 gauge from battery to distro block, then 0 gauge from d block to the skar (not scar), then whatever gauge you need to the highs amp. 8 gauge? i almost didn't believe you for a second. that is absolutely absurd. fix it right the FUCK now. edit: you ALWAYS ALWAYS ALWAYS use the biggest wire that you can fit in the power and ground terminals. Link to comment Share on other sites More sharing options...
Wicks Posted October 19, 2012 Report Share Posted October 19, 2012 Another good question, what load are you running on the amp (verified with a DMM)? Two sundown sa 12 dual 4 ddm @ 2.2 each So you have all four coils paralleled for a total 1ohm load at the amp? You sure you don't have any series'd for a higher load? Might explain why the amp isn't drawing more power. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
Guest Posted October 19, 2012 Report Share Posted October 19, 2012 if you're not wired exactly like this (all +'s together, and all -'s together) then you wired it wrong. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted October 19, 2012 Report Share Posted October 19, 2012 I let some one wire my stuff it has 4 gauge power to a block then 8 gauge to scar and 8 gauge to highs amp fix. it. now. 0 gauge from battery to distro block, then 0 gauge from d block to the skar (not scar), then whatever gauge you need to the highs amp. 8 gauge? i almost didn't believe you for a second. that is absolutely absurd. fix it right the FUCK now. edit: you ALWAYS ALWAYS ALWAYS use the biggest wire that you can fit in the power and ground terminals. if anything you get reducers to fit bigger wires in the terminals but 8 guage? that isnt even a 4th of the wire you need. the only thing the 8 gauge wire should be used for is going from the speaker outputs on the amp to the subs. what size speaker wire are you using anyways? 18gauge home stereo wiring? t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Banshee421 Posted October 19, 2012 Author Report Share Posted October 19, 2012 Can I just get one of those eBay 0 gauge wiring kits or are they b.s. I know it's skar but phone keeps auto correcting me Link to comment Share on other sites More sharing options...
alaskanzx5 Posted October 19, 2012 Report Share Posted October 19, 2012 Can I just get one of those eBay 0 gauge wiring kits or are they b.s. I know it's skar but phone keeps auto correcting me no, go to the forsale section here and look for someone selling some wiring or a system part out sale. can always find good deals in the forsale section of this forum. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Guest Posted October 19, 2012 Report Share Posted October 19, 2012 i wouldn't trust ebay kits at all. if you want a reputable kit, look at http://audiotechnix.com/products/amplifier-installation-kit/10-ga-amplifier-installation-kit i recommend the OFC wiring kit or you can also look at http://www.knukonceptz.com/productDetail.cfm?prodID=IXOS-PK0 other wire brands to look at would be stinger ofc, rockford fosgate, kicker. Link to comment Share on other sites More sharing options...
bighossf150 Posted October 19, 2012 Report Share Posted October 19, 2012 there's a pre order for 50' of shok cca 1/0 on caco for $50 shipped which is cheap as hell, everyone here talks down on cca but it would be plenty for a skar 1500 and leave you plenty left over for the big 3. Im honestly surprised the 8ga hasn't burned up yet. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s Link to comment Share on other sites More sharing options...
Guest Posted October 19, 2012 Report Share Posted October 19, 2012 the gain literally must be all the way down. absolutely no way would that wire still be intact if there was even a decent amount of power being drawn. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted October 19, 2012 Report Share Posted October 19, 2012 im just gonna assume the subs are wired with home stereo 18gauge wiring and he has massive box rise and voltage drop that is keeping the amp from performing even up to 30% of what it can do. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
