most watts from 50 amp fuse
ive gotta ask, i thats a rockford fused distro block in the last pic could you post a better pick. i have a rockford fused distrobution block that looks like the one in the pic and i have never seen anyone else with it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
you want the ground to have the least amount of resistance possible. adding shit in between the amp and the frame of the car (like a fuse holder) adds resistance.
Ohm load at amp is -1.01
lol you have the dmm leads wired inversely. either that, or the subs are wired out of phase (+ from sub to - on amp and - from sub to + on amp)
How did this thread reach 4 pages? It seems like a pretty easy question with a pretty easy answer. By now, the OP should know that he needs better wire and bigger fusing to get the most out of his amp. You also need to figure your wiring on your subs.
1.4 right on. thats just about 1 ohm when you account for internal dmm resistance (if its there). you can test that by just touching the two dmm leads together, and finding the number. subtract it from any and all resistance measurements you make. example: 1.4 from subs, .4 ohm resistance when you touch the dmm leads to each other, which means that the sub ohm load is actually 1.0.
yep exact same one i have, kinda suprises me. only the second one ive seen. figured they didnt sell a lot of them. i dont think they make them anymore.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 2557 Guests (See full list)
