DC Level 4 18" with TFS cone into a....... S60?
boxyhobo
I literally have no install skills but can do any imaginable with wood so if I get a design I can make
all u can do is try it out. if it dont work or u dont like the sound. start over with something new.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
where did yoy get 10" pvc? Is it just at home depot or lowes?
it may have been 8" im not sure on the size this was like 3 or 4 years back. my friend has a shop in my town and we put this box together in like 20min.. he just had that pvc at the shop so i dont know were he got it.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Oh Okay. The guy that had it before me had it in a 35x24x15 box with four 4" diameter pipes that were 22" long and it sounded great
heres a few vids of that 18 setup. the camera i was useing was a real junk p.o.s so it does not do the system justice...with a good camera u would have seen alot more flex.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
So the sub calls for 6 cubic feet in a vented enclosure. With the displacements if the sub and ports, you're barely above 4. If you add necessary bracing you're really close or right on 4 cubic feet. This might be ok if you're gonna feed the sub a TON of power, but you're only planning on 1000W.
Why not 2 12's, it's a little close to the cone area of 1 18'(226in^2 vs 254in^2), 4 cubes would be a proper box for them, you can seal it off from the trunk, and why are you only planning on feeding just 1k to a lv4, that power would be better off with a pair of lv 2's, or 1 lv 3.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   0 Members, 0 Anonymous, 1167 Guests (See full list)
