Amart88 Posted October 21, 2012 Report Posted October 21, 2012 Well, It's been a while, I was having a problem where one of my 2 BTl 15's was not moving. I have 2 Crescendo 3500's, one to each woofer. I noticed that one woofer was barely moving. I tested the Impendence multiple times of each coil and they were fine. i gain matched and set the amps with a dd-1. So after some more tests I sent the amp into crescendo to have a look at it. They said it was working 100% which puzzled me. I got it back yeaterday and the woofer is still not moving and the amp is on and drawing power. I can't figure out what this could be. They are both switched to output master, all filters are the same, both phases are at zero and I pop tested the woofer before hooking it up. I'm ready to give up. Any thoughts are appreciated. The woofer only seems to move from the other woofers pressure. Almost like the amp is holding the thing solid. My 2005 s10 blazer build. 4 zcon 18's walled.
MrSkippyJ Posted October 21, 2012 Report Posted October 21, 2012 Have you hooked it up to the other amp yet? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 Have you hooked it up to the other amp yet? yes, it works fine. The problem follows the amp My 2005 s10 blazer build. 4 zcon 18's walled.
1stgen Posted October 21, 2012 Report Posted October 21, 2012 good amp , and sub reading good, bad connection in speaker wires somewhere?
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 good amp , and sub reading good, bad connection in speaker wires somewhere? I don;t believe so as if I swap amps, the other woofer will not move and vise versa . I just read that a fuse can blow but not break and not let enough power through? maybe ill get a new in line fuse and see. My 2005 s10 blazer build. 4 zcon 18's walled.
fox_racin4 Posted October 21, 2012 Report Posted October 21, 2012 check RCAs 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 check RCAs Should I just check the jumper RCAs as the first amp works fine? My 2005 s10 blazer build. 4 zcon 18's walled.
fox_racin4 Posted October 21, 2012 Report Posted October 21, 2012 yes swap RCA from one amp to another too 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Amart88 Posted October 21, 2012 Author Report Posted October 21, 2012 yes swap RCA from one amp to another too What's the best way to check them Rca's been a long time since I had to do that. My 2005 s10 blazer build. 4 zcon 18's walled.
fox_racin4 Posted October 21, 2012 Report Posted October 21, 2012 Just take the rca from working amp and put into other amp 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
