So I blew my money on my subwoofer system thinking I could run a rca converter. Well I originally tried using an epicenter plus... Ya sounded like crap. Tried tapping off the door speakers tried after factory amp before factory amp right behind factory deck... Pulled my hair out. Stupid thing is, the sub would only sound correctly with the drivers door open. So would this hlc2 line converter be the way to go? The car is a 2005 corvette with bose. Any input would be greatly appreciated.
It depends. Most door speakers are usually crossosed over at the amp to only receive the lower frequencies. BUT Some factory systems like bose have certian frequency cut offs on the door speakers. Meaning that if you tap into the door speakers after the bose amp your LOC won't see the "full" range of lower frequencies you need for your amp. What you need to do is bypass the factory amp and tap the LOC "BEFORE" the amp. Or it won't work, Thats what I had to do with my bose system in my Chrysler any way.
Just something you might check into.
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Im currently using the HLC-2 with a factory bose setup in my cadillac. Im running it off the subwoofer channel (stock bose 12inch is removed). So far I have no issues.
Previously I tried using a Scosche SLC4 unit and could not get a clean signal out of the loc at all without out constant distortion, so I returned it to walmart. Once the units are shipping, Id see it being a good investment. Unless you buy a processor, but your talking more money there.
  • Who's Online   1 Member, 0 Anonymous, 575 Guests (See full list)
