kingkongthumpin Posted October 21, 2012 Report Posted October 21, 2012 I have 2 pioneer champion series pros they are dual 2 ohm! How can i wire them to 2ohms and wire them to a 2 channel amp thats 2 ohm stable? like some one told me the way to do it but i would have to run both subs to one channel and i dont want to do that i wanna run them on seperate channels like run the hot to the ground on one channel and do the same for the other sub how can i do this?
kingkongthumpin Posted October 21, 2012 Author Report Posted October 21, 2012 would i get enough power running them off of 1 channel?
ChevyBoy95 Posted October 21, 2012 Report Posted October 21, 2012 u cant If I read his post right, yes he can. Series the coils then parallel them together. What amp OP? Edit: nvm, will you are right, didn't see the part about OP wanting to do 1 per channel at 2 ohms. OP, you can do one sub per channel at 4 ohms if you series the subs coils. But that Is about it as far as 1 per channel Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
