The Saturn: 3 15's, AQ20 tons of fiberglass (Death-Horn) and low-lowz
I got the caged portion almost to a 'finishing-work' stage today, poured another batch of resin+sand and then followed up with a batch with mat mixed in to level everything out (roughly) and get ready for final mat layers ontop...
And finally got my first layer of 3oz mat layed down overtop of everything and overlapping onto the car's factory metal...roughed everything up with a wire wheel and also 40-grit sand paper beforehand and will be roughing everything up again before laying down more but that probably wont happen until the back is built up to the same height then it'll be finished with ~8 layers or so of 3oz mat :hello: :runaround:
And yes, the side panels are taken off for this that run along the roofline on the sides of the car. I will be masking everything off near the end where they sit to do the final bodyfilling work and paint...then they will go right over any imperfections @ the seems ;)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Poured a couple batches of resin+sand today...
I plan on CA-glueing a sheet/shirt from the car's frame down to the outer-top of the horn and wet with resin, once cured this will basically make a 'tub' ontop of the horn that I can go berserk on with no fear of it flowing anywhere :runaround: :hello:
More when it happens...
Team Tupperware
That poor saturn
Tehehe, it's fine with it...it barely sees 50 miles per month these days anyways and still runs great. Took it for a spin the other day to test out the new roof ;)
Team Tupperware
I pray for your computer to get well soon cuz I am tuned into this build! I wanna see a build with sp4s and a lot of power!!
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
What the fuck did I just see someone cut their roof out? Wtf
Then did I just see somone make a roof... :good:
Dear god what is going to happen in the rest of this build?
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
MORE !!!!!
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
  • Who's Online   0 Members, 0 Anonymous, 554 Guests (See full list)
