is this ok to do ?
uhmm, i know it says that all batteries should be the same or it could shorten the life of each battery.. what kind of amps and subs are you running? and even though you know, just make sure to fuze all of that!
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
You COULD, but ideally you would have the same brand of batteries all around.
Don't forget to fuse the positive wire close to the front battery, and the back battery!
no worries those are good stable batteries. same kind of battery at least your not mixing lead and deep cycle. plenty of people mix a standard battery under the hood with a better battery in the trunk and it works fine. make sure everything is fused 4 safety!
**actin bad like a kid at six flags**
rf 1500 bdcp @ 2 ohm on 2 12inch hx2 power
rf punch 500-2@ 4ohm pushing 2 8inch o2 mids
i have a 300 amp fuse up front and one for each amp from the rear battery
I think as long as the batteries are the same type, you should be fine. I seen people get a nice XS Power up front, and then get a bunch of cheap off brand agm batteries for the back battery supply.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Put one on the wire going from the front to the back, close to the back batteries too ;)
will do better safe then sorry
another question wile am at it can i run these four amps on this set up
1 rf 1500 bdcp
2 rf punch 500-2
1 rf punch 200-2
i have all 4 awg front to back and the big 3 do i need to change to 0 awg ?
  • Who's Online   0 Members, 0 Anonymous, 1806 Guests (See full list)
