Im kinda new to this sight, did not know where else to post this, i have recently gotten into car audio, i recently was given a stinger volt meter from a friend as a gift, i brought it down to one of our local electronics store and had them hook it up to a 12v volt tester and set the meter to 12v. then we double checked and it was all set. i got home and wired it up, positive to my battery, negative to the head unit and remote to the head unit, the meter is ready 14.4v on my stock electrical of a 95 civic ex. so my question is why is it this high? it does not seem right to be that high stock. any help would be appreciated!
Nope, sounds about right. Unless you mean it says at 14.4 V when you have a decent system on and playing, then that'd be a different story
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Make sure it's hooked up to the B+ on your amp!
*New vehicle and system coming soon.*
when the bass hits at decent volume its dropped to 11.4 on some songs,
11.4? That is horrible man!!! That will kill your amp, I would do the big 3 to help that and replace your stock battery with something better
What are you running?
i think it has a 70 amp alt stock.
x2 on what equipment you're running.
11.4 is pretty low voltage. anything under like mid 12's i'd start to worry. hope you aren't playing full tilt while idling. doing that with stock alts is stupid, imo.
Well I would do the Big 3, even if you didn't have a system. What amp are you running? Either way I'd try to upgrade the stock battery upfront, and if that doesn't help, add another one, even just a small one in the back.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Is that at idle, or while driving?
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
  • Who's Online   0 Members, 0 Anonymous, 1193 Guests (See full list)
