Blockshaker101 Posted November 3, 2012 Report Share Posted November 3, 2012 ok im not new to installing but i ran into an issue on the wife's 300. for some reason it has 2 power and 2 grounds on the wire harness i did a test and both wires are power and ground from the factory plug. but where the 12 volt ass. wire is there is no wire on the factory plug. then there are wires from the factory plug that are not on my harness . i would assume i have the wrong plug but i can not find a differnt one for my car. so i spliced the 12 volt ass wire into the 12 volt con. just to see if it would come on knowing that it will not shut off with the car but just checking. it works BUT....i have no radio stations, and yes i have the ant. adapter. but their is no stations coming in. just to make sure it wasnt the radio i put in a cd and it works, does anyone have any advise on both issues, thanks alot ahead of time. Link to comment Share on other sites More sharing options...
C-Fizzy Posted November 3, 2012 Report Share Posted November 3, 2012 Hmm, my car does not have a 12 volt ass wire. Stupid Toyota. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
recockulus1 Posted November 3, 2012 Report Share Posted November 3, 2012 What year is the 300? RECOCKULUS1 Link to comment Share on other sites More sharing options...
Blockshaker101 Posted November 3, 2012 Author Report Share Posted November 3, 2012 2005 Link to comment Share on other sites More sharing options...
recockulus1 Posted November 3, 2012 Report Share Posted November 3, 2012 As far as the switched power, its not provided in factory harness, have to go to fuse box. RECOCKULUS1 Link to comment Share on other sites More sharing options...
recockulus1 Posted November 3, 2012 Report Share Posted November 3, 2012 2005 What harness did you use? (aftermarket) RECOCKULUS1 Link to comment Share on other sites More sharing options...
recockulus1 Posted November 3, 2012 Report Share Posted November 3, 2012 2005 What harness did you use? (aftermarket) If you want to save yourself some trouble, pick up a Metra XSVI-6502-NAV, it will provide all connections needed. RECOCKULUS1 Link to comment Share on other sites More sharing options...
TheycallmeJT Posted November 3, 2012 Report Share Posted November 3, 2012 When i had my 08 Charger. i used the cig lighter as the switched instead of runin to the fuse box Link to comment Share on other sites More sharing options...
recockulus1 Posted November 3, 2012 Report Share Posted November 3, 2012 As far as the switched power, its not provided in factory harness, have to go to fuse box. I believe the radio functions have to do with the CAN crap.....What is your factory system specs? Like, 6 speaker BA, standard 4 speaker... RECOCKULUS1 Link to comment Share on other sites More sharing options...
army_guy137 Posted November 11, 2012 Report Share Posted November 11, 2012 The 300 has a canbus setup. You have a few options, first option is spend $125-ish on the aftermarket radio harness. Or Straight wire it like you did, and tap the ignition wire (ignition switch, black 5 pin plug, pin 3, pink/white wire) for your 12volt turn on. As far as the radio stations go, double check your connections. There may be a bad antenna connection somewhere. Link to comment Share on other sites More sharing options...
