Got A Lil Problem With A Simple Question.
so i got these PA speakers that i bought. There is a 600 watt 15" sub along with a 50 watt tweeter in each box. Both drivers are rated 8 ohms and they are wired in parellel so at the terminal it shows 4 ohms. my question is, is there a way to maby put a resistor in line with the tweeter so the sub gets most of the power. cause i already blew 2 tweeters cause i turned it up to much so it would hit some bass but then the tweeter could not handle it. So what are the possible options so that the sub gets more power and the tweeter gets less? Please let me know. thanks.
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
You'd have to use an amp for mids and another amp for highs since if you use a cross-over while parelleling the speakers, that cross-over will affect the woofer too.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
i can disconnect everything. currently the only thing in there for the crossover is a capacitor on the tweeter. I would like to put a coil on the woofer to block out the higher freq on the woofer. i can change the wiring. but maby a nother amp powering them is the only thing i can do.
In Dash
Rear Flip Down
thats what i originally thought but ive never seen a 8 or 4 ohm resisotr that would be able to handle like 45 watts or maby i should go with like 35 so the resistor burns out before the tweeter dose.
In Dash
Rear Flip Down
k i looked and found some lower ohm resistors. but they say there only rated to 10 or 12 watts? will these work? and how would i hook them up? im going to read up on some crossovers again at the 12volt.
In Dash
Rear Flip Down
k but then i saw some when they had them hooked up across, going from positive to negitve just before the tweeter but i dont know i think that is for a highpass filter. but a 12 watt resistor i dont think thats big enough? i have a 50 watt tweeter?
In Dash
Rear Flip Down
alrighty, yea i was looking on partsexpress and they just had a 10 and 12 watt, but i will look at radio shack tommorw after class and see whats up.
In Dash
Rear Flip Down
  • Who's Online   0 Members, 0 Anonymous, 1205 Guests (See full list)
