NEW ported box in chrysler 300 1 15 ?pics, HELP
ThreehundredC
On those dimensions you would need to have the sub firing upwards and really near the trunk lid which is likely the worse possible configuration, besides that, you would have about 3 cubes net ported, which is the tightest spec kicker lists (6 cubic feet being their maximum), I don't think that you will easily meet your goals in those conditions.
i got the wood today. its cut to 31.5 wide by 24 deep. 17 high.. the back is about 7-8inches from the back of the trunk .. the 300 has a bump on the rear deck so it wont push against the seat unless i cut the corner off or slant the top down. the big 8inch hole is almost touching the top of the box so i wanted it to fire thru there insted of back..JOE!
this is just balancing wood. nothing figured out yet 31.5wide 24 deep. 17? high mocked a 2.5 port i had them ruff cut while i was at homedepot
If you do have 31.5 wide, 24 deep 17 high then I would suggest doing this:
Enclosure Specifications:
Fb = 32 Hz
Vb = 4.5 ft^3
External Height = 17 in
External Width = 31.5 in
External Depth = 24 in
Port Width = 3 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 27 x 15 1/2
Front Internal = 25 1/2 x 15 1/2
Back = 31 1/2 x 15 1/2
Left & Right Sides:
Side 1 = 22 1/2 x 15 1/2
Side 2 = 23 1/4 x 15 1/2
Top & Bottom = 31 1/2 x 24
L Port Internal Assembly Parts:
Front to Back = 18 3/4 x 15 1/2
Extension = 2 x 15 1/2
Assembly guide:
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
