OrzechNJ Posted November 13, 2012 Report Posted November 13, 2012 kinda stupid question but I wanna try run my t2s active way and im not sure how to wire them up.. I put pos to mid speaker and neg to tweeter and than pos from tweeter to neg mid speaker ? thanks! edit: sth like that ? i know my english sux.. thats why i draw this that u know what im talkin about.. is it correct way ? its t600-4 amp and 2x t2 sets sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
ear2ear Posted November 13, 2012 Report Posted November 13, 2012 If you want to run them truly active, the mids and highs need to have their own channels. 2 mids per channel & 2 tweeters per channel. '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3
Bump4life Posted November 13, 2012 Report Posted November 13, 2012 thats not running them active. how is the woofer playing its proper frequencies? how is tweeter protected from 3000-5000hz and below? each speaker needs its own channnels. then you croossover those channels to the frequiencies the speakers can play Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
ROLEXrifleman Posted November 13, 2012 Report Posted November 13, 2012 2 tweeters channel 1 2 tweeters channel 2 Use x-over point 3500khz 2 Mids channel 3 2 Mids channel 4 Use x-over point between 80-150hz The t600 does not have an internal cross over capable of the proper point for the tweeters. You need another unit to feed signal to this amp Rolex you sicken me. Just let me finish my pie ~ Juice
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 does the t600 can produce enough power to run 2 mids per channel ? 2 tweeters channel 1 2 tweeters channel 2 Use x-over point 3500khz 2 Mids channel 3 2 Mids channel 4 Use x-over point between 80-150hz The t600 does not have an internal cross over capable of the proper point for the tweeters. You need another unit to feed signal to this amp maybe if I run the tweeters with the crossover it be good enough ? if no what I should get.. The reason why I ask is that the tweeters are much louder than the mids and I know that mids could play louder but I dont wanna put the volume up cause I dont wannadmg to the tweeters.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Bump4life Posted November 13, 2012 Report Posted November 13, 2012 the t600 is way more than enough to run 2 mids to. what exact model do you have? Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 t600-4 sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
barney91 Posted November 13, 2012 Report Posted November 13, 2012 What are your settings on the crossovers right now Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
OrzechNJ Posted November 13, 2012 Author Report Posted November 13, 2012 -2 on all crossovers axis : off sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Jessica Posted November 13, 2012 Report Posted November 13, 2012 I think the easy solution to your problem is to flip the switch in the crossovers that came with your t2's to the bi-amp setting. run one channel to the tweeter in and one channel to the woofer in. then hook the tweeter to the tweeter out and woofer to the woofer out. Then you can dial back the gain on the channel your tweeter is hooked to. Also, the crossover has a -3db setting or something like that. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
