Active wiring
OrzechNJ
kinda stupid question but I wanna try run my t2s active way and im not sure how to wire them up..
I put pos to mid speaker and neg to tweeter and than pos from tweeter to neg mid speaker ?
thanks!
edit:
sth like that ? i know my english sux.. thats why i draw this that u know what im talkin about.. is it correct way ? its t600-4 amp and 2x t2 sets
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
If you want to run them truly active, the mids and highs need to have their own channels.
2 mids per channel & 2 tweeters per channel.
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
thats not running them active. how is the woofer playing its proper frequencies? how is tweeter protected from 3000-5000hz and below? each speaker needs its own channnels. then you croossover those channels to the frequiencies the speakers can play
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
2 tweeters channel 1
2 tweeters channel 2
Use x-over point 3500khz
2 Mids channel 3
2 Mids channel 4
Use x-over point between 80-150hz
The t600 does not have an internal cross over capable of the proper point for the tweeters. You need another unit to feed signal to this amp
Rolex you sicken me.
Just let me finish my pie
~ Juice
does the t600 can produce enough power to run 2 mids per channel ?
2 Mids channel 3
2 Mids channel 4
maybe if I run the tweeters with the crossover it be good enough ? if no what I should get..
The reason why I ask is that the tweeters are much louder than the mids and I know that mids could play louder but I dont wanna put the volume up cause I dont wannadmg to the tweeters..
the t600 is way more than enough to run 2 mids to. what exact model do you have?
BMW M340 xDrive
I think the easy solution to your problem is to flip the switch in the crossovers that came with your t2's to the bi-amp setting. run one channel to the tweeter in and one channel to the woofer in. then hook the tweeter to the tweeter out and woofer to the woofer out. Then you can dial back the gain on the channel your tweeter is hooked to. Also, the crossover has a -3db setting or something like that.
  • Who's Online   0 Members, 0 Anonymous, 2169 Guests (See full list)
