12" level 4 m1s box design help
Nate Futuristic
undecided if i should do areo port
or slot port
subs are 2 dc level 4 m1s with xl coils/reinforced surround (cj said they should take 1700ish, corona_jeff said 1250rms each)
power will be 2 aq2200ds wire to a safe 2 ohm final load
(id say 1500-1800rms each roughly)
going in a 2000 mustang (sealed trunk)
i want low tuning 29-30hz
this is what i got with torres for the aero port (if this is good ill just do this but im worried about bracing)
14H x 34W x 22D
is this enough port area?
dc reccomends 1.5 cube per subs ( i know its kinda bigger)
anyone wanna design me a slot port (sub forward port forward/center)
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Is 7sq per cu ft to low?
I think im gonna shrink the box some closer to dc specs but any advise will help. ;)
Joel x help a brother out :)
Or anyone for thst matter
On your space nothing very nice can be done:
Enclosure Specifications:
Fb = 31.9 Hz
Vb = 3.5 ft^3
External Height = 14.5 in
External Width = 34 in
External Depth = 24 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 14 1/2 x 13
2x Front Internal = 13 x 13
Back = 34 x 13
Left & Right Sides: 22 1/2 x 13
Top & Bottom = 34 x 24
Shared Port Internal Assembly Parts:
2 x Front to Back = 20 3/8 x 13
2 x Extension = 8 3/16 x 13
Assembly guide (generic dimensions):
Had to go over your dims a bit, still port area is only fair, some more space to work width would be nice. A single 6" aero for that setup is not an option IMO.
I was thinking a 8in but tuning would be stupid high like 38 and that seems a lil high for these woofers
Any input with a 8?
Bump for aeroport design i dont care if the aeroport has to stick out!!
See if you can get 5" PVC pipe locally, a couple of those could do the job.
I sent you a pm dunno if you got it but hook me up with youe paypal the ladt box you designed for me worked perfect lol
I just want one that doesnt have any 45s or thst triangle in the middle of the port
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
