how to wire up second amp?
Ok guys I have a 130 amp alternator with stock battery and big 3 in 1/0 with 300 amp fuse, 1/0 with 300 amp fuse ran to back battery (stinger spv70) 1/0 from that to a powerbass 4000d and now will be adding a Rockford fosgate 1000.4 it takes 4ga wire. Should I run that from the back battery or the front battery? Powerbass amp can pull 300 amps and Rockford can pull 150 at full tilt. Yes I know I will need more batteries soon.
Run it from the back battery. You need a separate fuse for the 4 gauge wire.
P.S. power would be supplied from both batteries no matter which the amps were connected to.
P.S.S. that's a lot of power for such a small electrical.
Eclipse cd7000
I wasn't sure if that would over power the fuse or not. I won't have the ohm load that low as of now.
I know, I'll be getting a few more batteries and more wire after Christmas. I need to find an alternator too, I emailed a few companies cuz I couldn't find one but never got a response.
Thanks for the help!
you need a fuse between the rear batt and each amp.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1906 Guests (See full list)
