my car wont stay idled
ok well whenever i rev my car up and let off it gets a really low idle then dies, and i have to start it up and idles somewhat fine until i press the brake then it gets another rough idle, i cant even be in traffic because all the stop and go that goes on due to it dying any thoughts guys?
Take it to the auto parts store like advance auto, auto zone and the like and have them pull the codes and see which one/ones are bad.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
sounds like a map senser issue... could also be TPS or idle control value.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
i cleaned the TPS as soon as i got the car, and had a buddy run the codes, and there was nothing that jumped out at him besides the mis firing
I had a map sensor go bad on me and caused the car to idle poorly till i replaced it.
I'm not saying 100% that that is the problem but you'll need to pull the codes and see.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Without the CEL on, I don't think you'll catch it with a reader. Spark plugs, wires, cap, and rotors are cool?
Hmm... If it drives fine and just wont stay on at idle, either it's not ready airflow would be my guess. With that said, i would troubleshoot all the sensor to make sure nothing is loose of malfunction. Check your vacuum line as well.
