Miguels Posted November 21, 2012 Report Share Posted November 21, 2012 The X Series is back, and better than ever! New larger voice coil, now 3". Higher power handling, now rated at 750rms.The X Series of subwoofers is our all around daily sub. We offer the BP option (a machined compression plug), for increased cooling and higher thermal powerhandling. A multilayer foam surround is attached to a fiber impregnated kraft pulp cone which helps keep things under control in high power applications. A 3" 4 layer aluminum voice coil yields 20mm of Xmax while keeping the motor force high. The X series will work in most enclosure types (sealed, ported, bandpass). Light weight and versatile, the X Series works in a variety of applications from incredibly detailed sound quality systems, to ground pounding multi sub monsters. It comes standard with a white Fi logo on a rigid pressed kraft cap with the option of our hard dustcap and choice of colored Fi logos.Features: X Series: 10”, 12”, and 15" Dual 2 and Dual 4 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 4 layer coil Single high grade magnet Triple progressive spiders Optional BP Cooling X15 DUAL 2 | DUAL 4 Fs: 30.0 Hz | 30.0 Hz Re: 1.4 Ohms/coil | 2.8 Ohms/coil Qms: 7.48 | 7.48 Qes: .57 | .57 Qts: .53 | .53 Mms: 212g | 212g Cms: 0.00mm/N | 0.00mm/N Sd: 810cm^2 | 810cm^2 Vas: 121.1 l | 121.1 l Spl: 89.5dB 1W/1m | 89.5dB 1W/1m Bl: 14.01 N/A | 19.81 N/A Xmax: 20mm Rms: 750W Sealed box: 1.5-2.5 cuft Ported box: 3-5cuft @ 33Hz Sub OD: 15.625” Cut ID: 14.125” Mounting depth: 7.5” Displacement: 0.09cuft my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
C-Fizzy Posted November 22, 2012 Report Share Posted November 22, 2012 Haven't they already released the x series? Like 2 years ago? under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
Miguels Posted November 22, 2012 Author Report Share Posted November 22, 2012 wasnt that the SP4? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
DustinBolt Posted November 22, 2012 Report Share Posted November 22, 2012 there was an x series before but it got discontinued and this is the new version of it, and the sp4 came out last year at this time. 1997 BMW 528i Fi ssd 12 6th order box Build Log- http://www.stevemeadedesigns.com/board/topic/144835-rebuild-in-the-bmw-6th-order-time-update-1113/ Link to comment Share on other sites More sharing options...
Miguels Posted November 22, 2012 Author Report Share Posted November 22, 2012 if they made a new FI line im sure the new SMD is coming out soon my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
DustinBolt Posted November 22, 2012 Report Share Posted November 22, 2012 the x series is the lowest line of subwoofers from fi 1997 BMW 528i Fi ssd 12 6th order box Build Log- http://www.stevemeadedesigns.com/board/topic/144835-rebuild-in-the-bmw-6th-order-time-update-1113/ Link to comment Share on other sites More sharing options...
